cnc Postat Martie 23, 2014 Partajează Postat Martie 23, 2014 buna seara la acest tv am gasit memoria defecta am scris alta memorie am montato, tv merge bine recunoaste telecomanda are dimensiunea pe verticala micsorata da ca stie cineva cum se intra in meniu de service Link spre comentariu
santamihai Postat Martie 23, 2014 Partajează Postat Martie 23, 2014 1 - Select PR. number 91 2 - Adjust sharpness to minimum and exit all menus. 3 – Within 2 seconds press the key sequence : RED - GREEN - menu http://elektrotanya.com/daewoo_tv_cp520 ... nload.html Link spre comentariu
