KIDRA Posted November 24, 2008 Share Posted November 24, 2008 Are sasiu 11AK19-8A,imaginea este desfasurata cam 15 cm. cu limitare mai mare jos .Limita inferioara a imaginii nu este stabila ,are mici fluctuatii. Am probat TDA 8356,schiimbat cond.el,si inainte sa probez jungla TDA8840 vroiam o parere daca a mai intalnit cineva acest defect. multumesc, Quote Link to comment Share on other sites More sharing options...
Join the conversation
