kostel Posted January 15, 2007 Share Posted January 15, 2007 TV porneste din stand-by cateva secunde dupa care se opreste si clipeste ledul de 4 ori.La o noua repornire face la fel.Nu stiu ce inseamna aceste clipiri.Poate are cineva vreo idee :prayer: Link to comment
codrut Posted January 20, 2007 Share Posted January 20, 2007 incearca sa schimbi dioda ''smd''din sursa de alimentare care alimenteaza ic:tda 16846 Link to comment
paun nelu Posted January 24, 2007 Share Posted January 24, 2007 ancearca sursa daca fct. e primordiala. Daca nu mai vrb. Link to comment
palcu ion Posted September 23, 2010 Share Posted September 23, 2010 sa nu mai deschid alt topic,revin cu un defect similar,cu precizarea ca dupa incercari repetate de pornire,cu oprirea si pornirea tv din butonul general,tv porneste si "la cald" merge ok fara probleme,deci defectul se manifesta "la rece"!poate ca a rezolvat cineva un astfel de defect,cel putin ciudat...mentionez ca tot ce inseamna C electrolitic pe filtrajele sursei iese din discutie Link to comment
suciuclaudiu Posted September 24, 2010 Share Posted September 24, 2010 condi sau lipituri cadre....succes Link to comment
mariancalinescu Posted September 24, 2010 Share Posted September 24, 2010 Intrati in service si setati Vguard : 00. Link to comment
palcu ion Posted September 25, 2010 Share Posted September 25, 2010 am reusit sa intru in service dar n-am gasit sau cel putin n-am avut timp sa gasesc optiunea v guard,tv s-a oprit,aceleasi 4 clipiri de led,iar acum nu mai doreste sa porneasca... Link to comment
naebv Posted September 26, 2010 Share Posted September 26, 2010 Montati o memorie noua 24C08 scrisa cu dumpul atasat. Link to comment
mercenarx Posted September 26, 2010 Share Posted September 26, 2010 cum spunea si dl mariancalinescu, setati din ms vguard =00 , sau in cazul in care exista ,integritatea diodei d104pentru a avea timp sa faceti setarea in ms , dati tensiunea de screen mai mare (pana la aparitia cursei inverse), apoi tv-ul nu se va mai opridupa ce intrati in ms , este posibil sa nu puteti vedea instructiunile datorita pozitiei acestora (pozitionare mult in stanga); si pentru aceasta situatie aveti in meniu service optiunea de reglare a pozitiei screen-ului (nu mai stiu sigur , parca OSD POS , este...) Link to comment
palcu ion Posted September 26, 2010 Share Posted September 26, 2010 mutumesc de sfaturi,spre seara o sa incerc si vedem ce va iesi Link to comment
palcu ion Posted September 26, 2010 Share Posted September 26, 2010 din pacate e imposibil de intrat in sm,totusi am schimbat mem cu dump verificat,d 104,t504,505,diodele pe alimentare cadre si chiar finalul de cadre................rezultatul e acelasi:apare rastru ca si cum ar fi lipsa 200v si chiar mai urat,seamana cu defect de cadre la sasiele cu tiristor pe cadre cu tea 2029.... iar in cateva secunde liniile se opresc si se reia "ciclul"de 4 clipiri de ledinteresant e ca la prima pornire azi, a avut pentru vreo 10 sec si imagine BUNA,dar doar atat,de atunci nici macar un purice n-am mai vazut! Link to comment
tv1 Posted September 27, 2010 Share Posted September 27, 2010 Rezistenta R723=220 ohmi de pe placa TK ( cea care pune impreuna cu D704 grila 1 la masa ) este OK ? Link to comment
palcu ion Posted September 27, 2010 Share Posted September 27, 2010 o sa verific si va tin la curent Link to comment
palcu ion Posted October 1, 2010 Share Posted October 1, 2010 da,e ok,nimic nu pare in neregulaacum porneste doar cu rastru,fara imagine sau purici si nu mai arata nici osd si dupa max 10 sec se opreste!poate mai are cineva vreo idee inainte de a pune diagnosticul procesor defect Link to comment
