alex26 Posted November 15, 2014 Share Posted November 15, 2014 Buna ziua. Acest tv. l-a adus cineva, si initial avea doar sunet si o dunga alba subtire in partea de sus. L-am desfacut am verificat ceva condensatori si pareau ok. la esr. Am zis sa il alimentez si totul mergea ok ,sunet ok si imagine perfecta, fara sa-i fac nimic. Am miscat de placa am lovit in toate partile crezand ca este ceva lipitura rece, dar nimic, functioneaza bine cu o singura exceptie. In standby am un zgomot suparator, foarte sesizabil, cel putin cu carcasa demontata. Cand porneste acest zgomot dispare, deci problema pare undeva in circuitul de standby, dar ce ar putea cauza acest zgomot? Va multumesc. Link to comment
dan cod Posted November 15, 2014 Share Posted November 15, 2014 Schimba conzii din sursă. Link to comment
alex26 Posted November 15, 2014 Author Share Posted November 15, 2014 (edited) In primar am doar 2 condensatori electrolitici, de 33micro si cel de 220micro la 400V. Ambii schimbati, problema e la fel. Am refacut ceva lipituri reci, am mai schimbat 3 condensatori, degeaba.Sa fie din chopper? Edited November 15, 2014 by alex26 Link to comment
alex26 Posted November 15, 2014 Author Share Posted November 15, 2014 Mai am un sasiu identic, dar defect in alta zona si nu stiu ce sa iau de pe acesta. Ma gandeam la bobine sau ceva tranzistor . Nu am alte idei. Link to comment
alex26 Posted November 17, 2014 Author Share Posted November 17, 2014 Am schimbat toti electroliticii din primar si secundar, tensiunile sunt ok., chiar si C804 si C805,dar degeaba, parca tiuitul este mai puternic acum. Link to comment
dan cod Posted November 18, 2014 Share Posted November 18, 2014 Poate țiuie traful chopper. Link to comment
alex26 Posted November 18, 2014 Author Share Posted November 18, 2014 Tensiunea in standby pe condensatorul de filtraj este 260v, iar in on , scade la 250V. Tensiunea b+ este 125 V atat in standby cat si in on. Link to comment
dan cod Posted November 18, 2014 Share Posted November 18, 2014 In priza cat este?cam puțin 260V acolo. Link to comment
alex26 Posted November 18, 2014 Author Share Posted November 18, 2014 (edited) Asta e problema ca in priza imi arata 201 - 202V , iar cu alt aparat imi arata 198 - 199V. Condensatorul l-am schimbat din nou, original era 220 micro la 400V, nu am avut si am pus 100 micro la 450v, nou, cumparat de la dl. din Arad. Prima data am pus unul de 180 micro produs de Nichicon. Edited November 18, 2014 by alex26 Link to comment
dan cod Posted November 18, 2014 Share Posted November 18, 2014 Daca in priza e așa puțin e normal sa fie puțin si pe condiul ala dar tot trebuie sa meargă tvul. Link to comment
alex26 Posted November 18, 2014 Author Share Posted November 18, 2014 Televizorul functioneaza perfect, doar ca in standby are un tiuit foarte deranjant. Eu de exemplu in timpul noptii cand e liniste si se aude orice ,nu as putea adormi cu acest tv. in camera. Link to comment
valangjed Posted November 18, 2014 Share Posted November 18, 2014 Daca a avut 220 micro, eu zic ca trebuia sa-i puneti macar 150 micro la 400V.Incercati sa "dublati" cond-ul de 100/400 cu inca unul , la fel, si vedeti daca mai "bazaie".Cam putin 260V!Daca si tensiunea de retea e mica ... Link to comment
alex26 Posted November 19, 2014 Author Share Posted November 19, 2014 (edited) Nu a fost necesar suplimentarea condensatorului de filtraj, tensiunea la priza este azi de 231v. A crescut si tensiunea mea pe cond. la 310v si in on la 300v. Am inlocuit azi si puntea redresoare, dar tiuitul este tot prezent. Choperul nu il pot inlocui ca nu se potriveste cu ce am eu. Edited November 19, 2014 by alex26 Link to comment
Florinel TV Posted November 19, 2014 Share Posted November 19, 2014 (edited) inceraca sa schimbi si L801 eu am mai avut cazuri de astea si verifica si curile de pe secundar sursa Edited November 19, 2014 by Harhas Florin Link to comment
