Guest gabi_1981 Posted December 15, 2006 Share Posted December 15, 2006 ce stiti despre uher uma400 cu stk4050?eu am unul si s-a stricat. Link to comment
Palade Vlad Posted December 15, 2006 Share Posted December 15, 2006 Verifica daca ai tensiune continua pe iesire.Daca ai, mai mult ca sigur este dus STK-ul... Link to comment
Guest gabi_1981 Posted December 15, 2006 Share Posted December 15, 2006 nu pot verifica pt k nici releul care cupleaza boxele nu functioneaza.probabil k protectia isi da seama k ceva nu merge si nu cupleaza releul.mi-ar trebui o schema si nu gasesc deloc Link to comment
adi_0106 Posted December 15, 2006 Share Posted December 15, 2006 daca nici releul nu cupleaza e clar ca ai cc pe iesire si ..... stk-urile sunt arse Link to comment
joe Posted December 15, 2006 Share Posted December 15, 2006 uite aici skemada nu prea ai c sa ii faci pt k sigur e unu di ele arse.amndoua mai greu da unu e sigur.sa ai bafta Link to comment
Guest gabi_1981 Posted December 15, 2006 Share Posted December 15, 2006 schema stk-ului o am si eu.nu am schema amplif-ului Link to comment
Palade Vlad Posted December 16, 2006 Share Posted December 16, 2006 Schimba STK-ul ca e ars sigur... Link to comment
Guest gabi_1981 Posted December 16, 2006 Share Posted December 16, 2006 am gasit si eu ceva stk-uri da nu stiu dak sunt bune.de unde pot cumpara stk-uri originale? Link to comment
zal Posted December 23, 2006 Share Posted December 23, 2006 Un STK original e greu de gasit si afara, pe la noi e plin de chinezarii. Ca sa-ti faci o idee, tot ce gasesti intre 300000 si 650000 sau chiar 800000 si tin intre 1 secunda si pina dai mai tare. Nu ai nevoie de schema amplifului ca nu preul de ton e stricat ci finalii. Ia zi, ai pus 4 boxe de 8 ohmi pe el sau 2 de 4 ohmi? Daca aveai STK4048 puteam sa-ti dau originale dar asa... Bafta! Link to comment
Guest gabi_1981 Posted January 12, 2007 Share Posted January 12, 2007 am pus 2 boxe de 4ohmi.greseala mea!recunosc!am inlocuit stk-ul si acum merge bine.problema e ca nu scoate nici pe departe 200w desi consuma 900w de la sursapot sa-i fac ceva sa scoata mai mult? Link to comment
joe Posted January 12, 2007 Share Posted January 12, 2007 dc trafu ala e in satre sa traga 900w din priza..........eu zic k e periculos ....da' numai k nu e asa.k sa ii maresti puterea ii faci alt traf mai puternic cu o tensiune mai mare pe sec .....da' nu prea mare totusi. Link to comment
Guest gabi_1981 Posted January 12, 2007 Share Posted January 12, 2007 totusi de ce consuma 900w?eu am boxe cu dif tonsil de 80w si ar trebui sa iasa fum din ele cand dau la max,nu? Link to comment
joe Posted January 12, 2007 Share Posted January 12, 2007 pai tocmai asta e..... k nu consuma.eu zic k dupa cum arata trnsformatoru' ala nu prea are cum.si da-mi un id de mes k sa nu mai stam pe forum ne miscam greu. Link to comment
zal Posted January 12, 2007 Share Posted January 12, 2007 Aici e intr-adevar o problema caci la catalog intre STK4048 de 150w si 4050 de 200w sint citiva volti diferenta la alimentare si totusi se lauda cu o putere mult mai mare. Ce tensiuni de alimentare ai acolo? Poate se mai poate trage de par STKul sa scoata mai mult cu o alta alimentare. Ca sa te lamuresti cu puterea consumata iti dau niste metode empirice destul de sigure. Vezi ce siguranta ai pe retea, inmultesti cu 220 si afli puterea max la care se arde siguranta, mai scazi din ochi putin (cam 25-33%) si rezultatul e aproximativ consumul maxim real. Sau ca sa vezi puterea aproximativa a trafului, masori cit de cit exact aria sectiunii lui (in cm patrati), si o inmultesti cu ea insasi (ridici la patrat). La acest rezultat care e aproximativ puterea max suportata de traf timp indelungat (sa zicem 1 ora) poti sa adaugi inca 30-50 % in plus (asta in functie de calitatea tolelor) ca sa afli puterea de virf suportata de traf pentru scurt timp pina se incinge periculos (sa zicem 5 minute, sau o melodie cu volumul la maxim). Explicatia e ca toate firmele subdimensioneaza trafo din economie de materiale, bazindu-se pe ideea ca nu asculti tot timpul cu volumul la maxim si trafo nu se va arde prea repede. :smt005 Link to comment
Guest relu_relu Posted July 29, 2011 Share Posted July 29, 2011 Un STK original e greu de gasit si afara, pe la noi e plin de chinezarii. Ca sa-ti faci o idee, tot ce gasesti intre 300000 si 650000 sau chiar 800000 si tin intre 1 secunda si pina dai mai tare. Nu ai nevoie de schema amplifului ca nu preul de ton e stricat ci finalii. Ia zi, ai pus 4 boxe de 8 ohmi pe el sau 2 de 4 ohmi? Daca aveai STK4048 puteam sa-ti dau originale dar asa... Bafta!sal cu cat le dai 4048 2 buc Link to comment
