Mays Posted September 12, 2014 Share Posted September 12, 2014 Tv Brandt 639X/TX807C sasiu 36130RIB. Probleme la prima vedere, sursa are un bazait accentuat, iar tv nu iese din stby clipeste de 2 ori ledul si atat. L-am desfacut si am gasit finalul 1803DHI sarma acesta neavand radiator pe el din constructie. Va rog sa-mi spuneti ce echivalenti sunt pentru 1803DHI si ce ar trebui verificat la acest sasiu pentru a nu se mai arde finalul, si care ar fi cauza bazaitului sursei. Multumesc Link to comment
Mays Posted September 12, 2014 Author Share Posted September 12, 2014 (edited) BU 808DFI credeti ca ar fi echivalent am cateva bucati si am vazut ca ar corespunde doar ca BU are 5A si 1803 8A la tensiuni vad ca sunt la fel, cat si la w ambele au 50w. Un ST1803DHI vad ca este in jur de 35 de lei pe net (in magazin sau la comanda cu transport sare lejer de 40 de lei) mult prea mult pentru un astfel de tv. Edited September 12, 2014 by Mays Link to comment
Florinel TV Posted September 12, 2014 Share Posted September 12, 2014 ar merge BU2508DF BU4508DX bu 808 este darlington trage cu ochiu aici ElectronicService-SHOP Link to comment
cristybadea Posted September 12, 2014 Share Posted September 12, 2014 (edited) Cauta si pune un tz D2499,schimba C-ul pe alimentare trafoo driver di nu v-a mai avea probleme Edited September 12, 2014 by cristybadea Link to comment
Mays Posted September 12, 2014 Author Share Posted September 12, 2014 (edited) Am inteles BU808 este darlington. Am mai gasit prin piese BU908 - NPN / S-L/TV-SN/HA / 1500 / 700V 8A / 125W ce parere aveti ? Edited September 12, 2014 by Mays Link to comment
Florinel TV Posted September 12, 2014 Share Posted September 12, 2014 (edited) Am mai gasit prin piese BU908 - NPN / S-L/TV-SN/HA / 1500 / 700V 8A / 125W ce parere aveti ? asta nu are dioda si rezistenta aici gasesti piese electronicservice.shopmania.biz/ Edited September 12, 2014 by Harhas Florin Link to comment
dan cod Posted September 13, 2014 Share Posted September 13, 2014 1803 are cristronic la preturi bune.Eu de la el iau. Link to comment
Mays Posted September 13, 2014 Author Share Posted September 13, 2014 Am reusit sa-l gasesc la un pret mai bun, nu-l aveau pe stoc dar il aduc luni. As vrea daca are cineva schema acestui sasiu sa mi-o dea si mie. Care este C-ul din alimentare final ? In sursa toti condensatorii sunt albastrii de 85c foarte prosti am mai avut probleme cu accea marca desi erau noi, o sa-i schimb preventiv. C-ul de pe alimentare primar este de 68uf/400v in loc de 100uf. Pana imi vine 1803 o sa schimb condensatorii, si o sa vad cum fac sa scap de zgomotul sursei. Inco o data care are o schema il rog sa ma ajute. Link to comment
dan-a2 Posted September 13, 2014 Share Posted September 13, 2014 http://elektrotanya.com/thomson_chassis_tx807.pdf/download.html Link to comment
Florinel TV Posted September 13, 2014 Share Posted September 13, 2014 (edited) Am reusit sa-l gasesc la un pret mai bun, nu-l aveau pe stoc dar il aduc luni. As vrea daca are cineva schema acestui sasiu sa mi-o dea si mie. Care este C-ul din alimentare final ? In sursa toti condensatorii sunt albastrii de 85c foarte prosti am mai avut probleme cu accea marca desi erau noi, o sa-i schimb preventiv. C-ul de pe alimentare primar este de 68uf/400v in loc de 100uf. Pana imi vine 1803 o sa schimb condensatorii, si o sa vad cum fac sa scap de zgomotul sursei. Inco o data care are o schema atunci schimba toti elctrolitici din primaru sursei si mai vorbim Edited September 13, 2014 by Harhas Florin Link to comment
Mays Posted September 14, 2014 Author Share Posted September 14, 2014 Am schimbat electroliticii, am gasit un D2499 l-am pus pana imi vine 1803 vad ca zicea cineva mai sus ca ar fi bun si d2499, a disparut zgomotul de stby, porneste am sonor dar n-am imagine, pe final linii am 132v, ceva pareri ? Link to comment
modoran Posted September 14, 2014 Share Posted September 14, 2014 Sasiul tau e cu TDA 9554 ? Daca da acesta e burdusit cu protectii, Verifica tensiunile de 3.3V si 8V, apoi cu osciloscopul daca ai semnal HOUT pana in baza final linii, precum si circuitul de feedback linii. Principalul suspect la acest sasiu ar fi trafo linii, am avut defect asemanator (sunet normal si atat si cauza a fost trafo linii, finalul a scapat intreg) Link to comment
Mays Posted September 14, 2014 Author Share Posted September 14, 2014 Sasiul tau e cu TDA 9554 ? Daca da acesta e burdusit cu protectii, Verifica tensiunile de 3.3V si 8V, apoi cu osciloscopul daca ai semnal HOUT pana in baza final linii, precum si circuitul de feedback linii. Principalul suspect la acest sasiu ar fi trafo linii, am avut defect asemanator (sunet normal si atat si cauza a fost trafo linii, finalul a scapat intreg) Da este TDA9554PS , am sa masor cand ajung la el, din pacate nu am osciloscop, am vazut ca aceste sasie au probleme cu Trafo Linii. Am si B+ marit la 132-135v cand normar ar trebui sa fie in jur de 100v. Totusi tv ul acesta zice omul este aproape nou si la cum arata il cred, luat acum 2 ani si folosit cateva zile, dupa il baga in priza o data pe luna, iar acum cand l-a reactivat dupa o zi a murit nici macar praf nu are in el si imi e greu sa cred ca s-ar fi dus trafo stand, cred ca nu are nici macar 100 de ore la activ. Link to comment
