Guest DINU A Posted September 10, 2014 Share Posted September 10, 2014 mai am unul tot traznit sasiu uoc-top cu procjungla tda12196 sursa c00765.Am gasit ci sursa c00765 si 2 diode din punte scc,le-am schimbat si a pornit alim. in st-by,- mai are si alceva, o schema rog frumos. Quote Link to comment Share on other sites More sharing options...
dan-a2 Posted September 10, 2014 Share Posted September 10, 2014 http://elektrotanya.com/kenstar_s2101c_s2102c_uoc_top_80pin_chassis.pdf/download.html Quote Link to comment Share on other sites More sharing options...
Guest DINU A Posted September 11, 2014 Share Posted September 11, 2014 Multumesc. Quote Link to comment Share on other sites More sharing options...
Join the conversation
