iuliantv Posted September 9, 2014 Share Posted September 9, 2014 tv allview ta4901f cu procesor tda11105ps/v3/3(NT11105PC323AG ) cunoaste cineva un cod mfy verificat? va multumesc Link to comment
iuliantv Posted September 9, 2014 Author Share Posted September 9, 2014 am rescris memoria cu dump buntz ctv1401,si acum merge cu cod mfy 1849 Link to comment
dan cod Posted September 9, 2014 Share Posted September 9, 2014 Inainte nu mergea cu codul asta? Link to comment
iuliantv Posted September 9, 2014 Author Share Posted September 9, 2014 Inainte nu mergea cu codul asta? .pe acest tv am gasit tranzistorul v502 c2655-g intrerupt,am inlocuit cu bd139 ,cu un mic radiator,am schimbat a1015,c1815,si ceva condesatori preventiv pe bv,dar tv-ul nu pleca din stby,totul parea ok,m-am gandit ca are tastele blocate,cu memorie goala nu mergea,asa ca am rescris alta memorie ,cu binul mentionat mai sus,si tv-ul a pornit,chiar din taste,am accesat meniul service ,,menu 6483,, cu ceva ajustari de geometrie si agc,dar spre surpriza mea se bloca in navigarea meniului service,si trebuia oprit din butonul de retea,am reintrat in menu service,am activat optiunea shiping,am oprit si repornit tv ul de la retea,am reintrat in menu service si am refacut setarile necesare,fara blocari,totul ok,am pus memoria originala ,dar tv ul nu pleca din stby,asa ca am montat-o pe cea scrisa,m-am gandit ca o fi corupt dumpul de pe memoria originala 1 Link to comment
palcu ion Posted September 10, 2014 Share Posted September 10, 2014 procesorul asta merge cu NP51 Link to comment
iuliantv Posted September 10, 2014 Author Share Posted September 10, 2014 procesorul asta merge cu NP51 tv ul a ajuns la propietar ,merge cu telecomanda originala,care in nici un caz nu e np 51,np51= cod mfy 550 Link to comment
Florinel TV Posted September 11, 2014 Share Posted September 11, 2014 aceasta telecomanda merge si la Goldy 218m2 Link to comment
palcu ion Posted September 11, 2014 Share Posted September 11, 2014 tv ul a ajuns la propietar ,merge cu telecomanda originala,care in nici un caz nu e np 51,np51= cod mfy 550 am intilnit tv care au aceleasi procesoare ca terminatie dar cu softuri diferite care folosesc din acest motiv tc diferite,ultimele fiind pe sasiu ete3 Link to comment
