Guest wolfsorin Posted September 2, 2014 Share Posted September 2, 2014 buna ,lcd axen de 19 inch ,la incet facea tot felul de aberatii,schimba programe singur ,volum etc,dupa care a murit in standby,...si nu mai porneste nici decum,...am tensiuni normale ,tot e bun nimic nu merge ,am schimbat si memoria,... Link to comment
leoncris Posted September 2, 2014 Share Posted September 2, 2014 Schimba push butoanele din bord prima data . Link to comment
Guest leon Posted September 2, 2014 Share Posted September 2, 2014 scoate mufa daca e posibil de la push butoane si receptorul de telecomanda sa ramana si pornestel din telec. Am si eu un tv lcd Axen mod.AX022LI-T2 are toate tensiunule sta doar in stand-by in rest nu face nimica is aprinse doar 2 leduri rosii,daca ma poate ajuta cineva multumesc anticipat. Link to comment
leoncris Posted September 3, 2014 Share Posted September 3, 2014 leon Sterge memoria , sau pune una ... nuda si va pornii. Link to comment
Guest wolfsorin Posted September 3, 2014 Share Posted September 3, 2014 am sters una dintre memorii ,are doua , am sa o sterg si pe cealalta,am scos si mufa de la push ,tot nu vrea ,sta ledul de stendby aprins si atat Link to comment
leoncris Posted September 3, 2014 Share Posted September 3, 2014 Mesajul era pentru "leon" .Tu trebuia sa schimbi doar push butoanele. Sper ca ai salvat datele initiale . Link to comment
Guest wolfsorin Posted September 3, 2014 Share Posted September 3, 2014 am sters memoria , nu vrea da le-am salvat ,am decuplat butoanele ,sunt cu touch,... Link to comment
Guest wolfsorin Posted September 16, 2014 Share Posted September 16, 2014 ARE CINEVA SCHEMA LA SURSA AXEN AYL150211 ,3BS0010714 cati volti trebuie sa am pe sursa la pinul on/off ?, mentionez ca nu e nici un volt Link to comment
BUGHIU Posted September 16, 2014 Share Posted September 16, 2014 Depinde de stare;0v off sau 2-5v on!! Link to comment
Guest wolfsorin Posted September 17, 2014 Share Posted September 17, 2014 in standby are 0 v, nu porneste din starea asta.... restul tensiunilor normale Link to comment
iuliantv Posted January 31, 2017 Share Posted January 31, 2017 (edited) salutare,un tv jws lcd 2246 acelasi chassis spc81b-1,momentan este la servici,nu am apucat sa sap prea mult in el,este blocat in stby,dupa spusele propietarului,a folosit telecomanda pana sa stricat,de gasit nu o mai gaseste,la folosit din pus bootoane pana nu a mai iesit din stby,pusurile inainte de a se defecta au lut-o razna,faceau functii aiurea(ceva foarte cunoscut pentru noi)a venit la noi pentru o telecomanda,noi avem rcw in vanzare,momentan,pusurile par ok,si nici nu am trecut la schimbarea lor,motivul e simplu ,clientul e cu venit minim negarantat si vrea sa iese cat mai ieftin cu putinta,daca se poate doar cu pretul telecomenzii,sa speram ca are noroc,si nu va trebui reparat.deci un cod rcw daca stie cineva,sau un cod mfy ce sa fie acceptat de rcw ,nu am avut timp de teste,ca eram aglomerati si la sfarsituöl programului,va multumesc Edited January 31, 2017 by iuliantv Link to comment
iuliantv Posted June 30, 2020 Share Posted June 30, 2020 defect ciudat cu batai de cap,televizorul rar pornea din stby cu backligt,si cand pornea pica in stby in circa 2 secunde de la pornire,defect bobina l11(spire in scurt,o bobina mica cat un c de 1mf 35v) de langa u2 l-am chinuit cu dumpuri ,am zis sa trec aici poate so mai chinui vre-o data cineva Link to comment
