Jump to content
adium
samsung CK 5081t
buna ziua,la acest tv am gasit final linii ars ,am schimbat acest tranzistor(2sd5072 ) ,la pornire a plesnit iar.am inlocuit si c recuperata . sa fie tr slab(luat de la mivarom)?la proba cu bec b+117v.o schema pe acest model are cineva? multumesc!
Share this post
Link to post
Share on other sites
c de recuperare a fost inlocuit inainte sau dupa ce a plesnit tz final.......daca inainte aveti trafo linii defect...daca nu c era in scurt sau intrerupt
spor si bafta
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
Important Information
