Jump to content
Sign in to follow this
sucium58
Tv-NEO 2100s
Buna ziua,
La acet tv. neo-tv-2100s, sasiu CY-PH2529TOP. am gasit ars finalul di sursa 3DD5011 si pre finalul 2sc3807 in schema e dat final 2sc4460 sunt echivalente.
Va multumesc
Share this post
Link to post
Share on other sites
...pe linga echivalente;ar trebui sa vedeti DE CE  s-au defectat cele doua?!?!?!
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
Important Information
