Jump to content
berluscony
VESTEL CHASSIS 11AK19P4
Salutare tuturor, am un tv cu chassis 11ak19p4 si functioneaza normal dar dupa aproximativ 30min-1h se arde bu2508af si nu gasesc motivul a intimpinat acest defect cineva
Share this post
Link to post
Share on other sites
De tensiuni ce ne spui?
Condensatori cu ESR marit , lipituri reci ...
Share this post
Link to post
c607=470/25-devalorizat,c611=6.2n/1500-lipituri,conector pl 601-pin3-4 lipituri reci,contacte imperfecte
Share this post
Link to post
diagonala mare
am sa il las sa functioneze sa vad daca se mai arde bu2508af il am pornit de 40min si functioneaza
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
