bubusmecherul Posted July 14, 2014 Share Posted July 14, 2014 Tv shinelco crtd-21s,problema cu imaginea,lipsa rastru,in partea stanga si in dreapta,am schimbat toti condesatori,+doi tranzistori din sursa,2sa1015,c1815,multifunctional are TDA11136PS/N3/3,final lini md1803,pe fisa ce duce la placa tfk de pe tub nu am cei 180v,am decat 156v,ce pot face.foto. Quote Link to comment Share on other sites More sharing options...
dan cod Posted July 14, 2014 Share Posted July 14, 2014 Banuiesc ca nu e cu tub de 90* si atunci are corectie EW.Acolo e problema . Quote Link to comment Share on other sites More sharing options...
bubusmecherul Posted July 14, 2014 Author Share Posted July 14, 2014 dom dan, are ecranul patrat,ce pot sa mai verific. Quote Link to comment Share on other sites More sharing options...
ionbel1 Posted July 14, 2014 Share Posted July 14, 2014 Nici un tv nu are ecranul patrat.Domnul Dan te-a intrebat daca este tub de 110 grade, atunci defectul este in etajul corectie est-vest Quote Link to comment Share on other sites More sharing options...
bubusmecherul Posted July 14, 2014 Author Share Posted July 14, 2014 pe eticheta ecranului scrie HUAFEI A51ERS357X440,In anume loc este etajul corectiei est-vest,sant si doua reglabile unde pot baga surubelnita,cand umblu la una din ele se mai largeste putin imagine. am uitat sa precizez,a fost si LA78041 defect,lam inlocuit cu LA7840,este vreo problema. Quote Link to comment Share on other sites More sharing options...
cristybadea Posted July 14, 2014 Share Posted July 14, 2014 Ce tensiune are pe B+? Quote Link to comment Share on other sites More sharing options...
dan cod Posted July 14, 2014 Share Posted July 14, 2014 Ce treaba are BVul cu defectul asta?ai ceva defect in EW clar chiar daca ecranul e patrat.Poti avea conzi devalorizati,rezistente etc. Quote Link to comment Share on other sites More sharing options...
bubusmecherul Posted July 14, 2014 Author Share Posted July 14, 2014 aveti cumva aceasta schema a sasiului. Quote Link to comment Share on other sites More sharing options...
dan-a2 Posted July 14, 2014 Share Posted July 14, 2014 E posibil si filtrajul pe B+ >> cat e tensiunea pe B+ ?? Quote Link to comment Share on other sites More sharing options...
leoncris Posted July 14, 2014 Share Posted July 14, 2014 http://www.filehost.ro/30583659/ELITE_14ES11_TDA111XX_LA78040_TDA1035_pdf/ Quote Link to comment Share on other sites More sharing options...
robert1000 Posted July 14, 2014 Share Posted July 14, 2014 Oricum, dupa cum se vede imaginea, nu mai are mult si-si da duhul tubul Quote Link to comment Share on other sites More sharing options...
dan-a2 Posted July 14, 2014 Share Posted July 14, 2014 (edited) Oricum, dupa cum se vede imaginea, nu mai are mult si-si da duhul tubul Raman la parerea mea > tensiunea pe B+ mai mica decat normal si filtrajul pe aceasta bara !! Edited July 14, 2014 by dan-a2 Quote Link to comment Share on other sites More sharing options...
BUGHIU Posted July 14, 2014 Share Posted July 14, 2014 Raman la parerea mea > tensiunea pe B+ mai mica decat normal si filtrajul pe aceasta bara !! Dupa cum arata marginile rastrului,drepte fara deformari specifice defectelor EW,si eu tind sa cred ca B+ este mai mica decat trebuie...chiar spune de tensiunea video ca e doar 156v!!! Din ce cauza....?? doar d-l Bubu' poate sa afle!!! Quote Link to comment Share on other sites More sharing options...
palcu ion Posted July 14, 2014 Share Posted July 14, 2014 (edited) dupa ce vei aduce u1 la +125v mai avem ce discuta,un tk 110grade nu are cum sa afiseze o imagine ok alimentat la cit ai tu acolo din prima poza e evident Edited July 14, 2014 by palcu ion Quote Link to comment Share on other sites More sharing options...
robert1000 Posted July 14, 2014 Share Posted July 14, 2014 (edited) Raman la parerea mea > tensiunea pe B+ mai mica decat normal si filtrajul pe aceasta bara !! Ma refeream la faptul ca, contrastul e foarte slab si n-o mai duce mult tubul. Aparte de defectul de EW:)))))) In fine, maine dimineata la prima ora domnul Bubu se va prezenta din nou pe forum , la lucru, si va coopera cu dumneavoastra pentru a rezolva acest defect.......si cu siguranta va repara tv-ul. De ce? Pentru ca nimic nu este imposibil pentru domnul Bubu! Eu totusi zic sa puna LA78041, am avut diverse probleme cand am incercat inlocuirea BV originale cu unele care am zis eu c-ar fi compatibile. Tv-ul a venit cu defectul BV ars. Nu prea cred eu ca proprietarul s-a uitat la tv cu desfasurare incompleta E-W. Asadar, eu unul nu prea vad cum sa se devalorizeze conzi sau rezistente "peste noapte". Dar...cine stie.... Edited July 14, 2014 by robert1000 Quote Link to comment Share on other sites More sharing options...
Join the conversation
