verdea Posted July 7, 2014 Share Posted July 7, 2014 Buna ziua a venit azi un amic sa l ajut cu un tv SONY model: KV 21FX30K SASIU FE2 cred ca scrie pe placa cu urmatorul defect clipeste ledul de stand by de 11 ori, cu 2-3 secunde si as face as dori daca se poate un sfat si eventual o schema daca ati intalnit aceasta problema va multumesc Quote Link to comment Share on other sites More sharing options...
Toni Marginean Posted July 7, 2014 Share Posted July 7, 2014 Schema o gasiti foarte usor, exemplu: http://www.electronica-pt.com/esquema/func-fileinfo/20684/ De obicei este de vina MCZ3001D - subiectul a mai fost discutat pe forum. Quote Link to comment Share on other sites More sharing options...
leoncris Posted July 7, 2014 Share Posted July 7, 2014 (edited) Verifica daca jungla este alimentata ... corect . ( Tensiunea de 8V ) Edited July 7, 2014 by leoncris Quote Link to comment Share on other sites More sharing options...
neculavasile Posted July 7, 2014 Share Posted July 7, 2014 mcz defect Quote Link to comment Share on other sites More sharing options...
verdea Posted July 7, 2014 Author Share Posted July 7, 2014 da se pare ca integratul din sursa este defect sa vad unde il pot gasi sa l cumpar multumiri pentru sfaturi Quote Link to comment Share on other sites More sharing options...
leoncris Posted July 7, 2014 Share Posted July 7, 2014 " se pare ca integratul din sursa este defect " - este defect , sau doar ... se pare ? Vezi la userul Cristronic . Quote Link to comment Share on other sites More sharing options...
Join the conversation
