adam stefan Posted July 5, 2014 Share Posted July 5, 2014 va salut la un tv roadstar sasiu beco cred e1 cale comuna nn5099k am schimbat norma sunet bg +dk am montat filtru cale comunak2960 ptr dk insa apare zgomot pe scris ma puteti ajuta va rog cu ceva sfaturi multumesc Quote Link to comment Share on other sites More sharing options...
palcu ion Posted July 5, 2014 Share Posted July 5, 2014 incearca cu alt filtru,poate ai si alte modele 29xx Quote Link to comment Share on other sites More sharing options...
adam stefan Posted July 5, 2014 Author Share Posted July 5, 2014 am incercat mai multe filtre care cu siguranta sunt ok dar stiu ca intotdeauna modelul asta m-a chinuit nu mai stiu cum o rez Quote Link to comment Share on other sites More sharing options...
palcu ion Posted July 5, 2014 Share Posted July 5, 2014 incearca un fin acord la caf Quote Link to comment Share on other sites More sharing options...
adam stefan Posted July 5, 2014 Author Share Posted July 5, 2014 incearca un fin acord la caf nu are bobina caf Quote Link to comment Share on other sites More sharing options...
palcu ion Posted July 5, 2014 Share Posted July 5, 2014 nu e sasiu e1,acela e cu tda 9145,daca nu spui mai multe..... Quote Link to comment Share on other sites More sharing options...
adam stefan Posted July 5, 2014 Author Share Posted July 5, 2014 asa e este cu doua procesoare si intra in sm cu contrast - Quote Link to comment Share on other sites More sharing options...
adam stefan Posted July 5, 2014 Author Share Posted July 5, 2014 multumesc am rezolvat pb se pare ca nn5099k nu prea stie sa faca dk am gasit o placa identica echipata cu procesornn5198k si am inlocuit procesor cale comuna nu mai face zgomot cam multa munca dar asta eo zi buna Quote Link to comment Share on other sites More sharing options...
palcu ion Posted July 5, 2014 Share Posted July 5, 2014 ca fapt divers.....nn era schimbat de cineva? Quote Link to comment Share on other sites More sharing options...
vasi47 Posted July 5, 2014 Share Posted July 5, 2014 http://www.schemeelectronice.com/1101/filtru-de-brum-50-hz/ Quote Link to comment Share on other sites More sharing options...
adam stefan Posted July 6, 2014 Author Share Posted July 6, 2014 ca fapt divers.....nn era schimbat de cineva? nu era schimbat tv era adus din italia era numai in norma bg trebuia sa-l transform bg +dk are acelasi sasiu cu tv de pe piata romaneasca numai ca difera jungla problema am mai intilnit-o in trecut si nu am rezolvat-o decit cu bistandard acum neavind bistandard l-am cam chinuit Quote Link to comment Share on other sites More sharing options...
Join the conversation
