Jump to content
Sign in to follow this
mar123
Tv. Nordmende-identificare sasiu
Am un tv. cu butoane pe margine vertical spate,pe carcasa placii electronice(orizontala,jos) ,pe o eticheta scrie :
Nordmende   SPECTRA 70kv,
BZ09 NM    EU 995.668N58,
AFD030415   ICC9(sasiu?).Daca va fi nevoie, revin cu poze.
 Care este modelul,sasiul pt.a cauta schema.Multumesc,Marian.
Share this post
Link to post
Share on other sites
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
