Jump to content
Sign in to follow this
djgeorge2k
Samsung LE26B350F1W
Salut,
Incerc sa repar un Samsung LE26B350F1W, care in timpul functionarii s-a oprit brusc.
Am gasit scurt intre pinii 3-4 CI UM801S = ICE3B0665J si siguranta FM802S = 2A sarita, acestea au fost inlocuite, acum se aprinde led-ul de standby, dar cand apas butonul power clipeste de 4 ori led-ul apoi se stinge, pe display nu apare nimic.
Tensiuni CNM802 fara conectare placa logica / cu placa logica.
1.on/off = 0.8V / 0V
2.stby = 5.2V / 5.2V
3.gnd
4.13V(S) = 12.9V/13.2V
5.gnd
6.gnd
7.5.3V = 5.2V / 5.2V
8.5.3V = 5.2V / 5.2V
9.gnd
10.13V(M) = 12.9V / 13.1V
11.13V(M) = 12.9V / 13.1V
12.inverter on/off = 4.7V / 5.1V
13.e-pwm = 5.8V / 2V
14.det_5V = 0V / 0.1V
15.sync = 0V / 0V
16.gnd
Sursa model: BN44-00291A
https://www.dropbox.com/s/eshj5597jesinhp/samsung_bn44-00291a.pdf
Orice informatie este binevenita.
Edited by djgeorge2k
Share this post
Link to post
Share on other sites
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
