Jump to content
Sign in to follow this
sorintv
Traf Daewoo sasiu CP-520F
 Buna! Traf defect. Cod original: 13625018D C06; 50H0000233.  Ce varianta "ergonomica" imi puteti recomanda.? Adica, nici original, si nici china (clona). Ceva adaptare de pini (resoclare), si reglaje din service.
 Va multumesc!
Edited by sorintvr
Share this post
Link to post
Share on other sites
1362.5018,
1362.5018A,
1362.5018C sunt date ca fiind hr8522 si sunt de 110grade
consultati intii schema,cablajul si alimentarea si vedeti daca seamana cu al dv cu terminatia D
pentru 90grade este HR8537,in principiu are recuperate de 13.5 si 43v pentru bv si 200v video,deci e usor de inlocuit
Edited by palcu ion
Share this post
Link to post
 Daewoo, Model: DTZ-29U3K S, 110*, +B 140v (cat am masurat cu "becul"). Am sa studiez schema.
Multumesc, d-le Palcu
Revin!
 Exclus varianta,  ELDOR 1362.5018 (Nou!), din motive "ergonomice"!!!
Edited by sorintvr
Share this post
Link to post
pune un alien,din cite am montat ,daca au mai revenit la reparat in timp,au venit cu alte defecte,trafurile au rezistat
Share this post
Link to post
 Am sa incerc varianta asta :1302.2001(BSC29-0175K, HR80306)
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
Important Information
