wlfu Posted July 3, 2014 Share Posted July 3, 2014 (edited) Va salut! Stie cineva de la ce ar putea veni acest defect . Ceva module sau este panelul defect ? Tv-ul este o plasma. Dungile sunt pe centrul plasmei. Multumesc anticipat ! Edited July 3, 2014 by wlfu Quote Link to comment Share on other sites More sharing options...
Guest cata82 Posted July 3, 2014 Share Posted July 3, 2014 (edited) Pai daca dati si o serie a TV-ului, o serie a placi de baza, serie panel sau o serie de sasiu poate va ajuta cineva.......Invatati-va sa scrieti cat mai multe detalii(procesor, jungla, audio, BV, panel, placa de baza, sursa, sasiu sau tensiuni masurate) despre TV-ul pentru care cereti sfaturi altfel veti astepta mult si bine! Edited July 3, 2014 by cata82 Quote Link to comment Share on other sites More sharing options...
wlfu Posted July 4, 2014 Author Share Posted July 4, 2014 Model Panasonic plasma TH-37PV45EH . Eu suspectez ecranul .Ce parere aveti ? Quote Link to comment Share on other sites More sharing options...
daisarqx Posted July 4, 2014 Share Posted July 4, 2014 display defect Quote Link to comment Share on other sites More sharing options...
wlfu Posted July 4, 2014 Author Share Posted July 4, 2014 De la ce este ,gazul din el ,pamblici ? Mai poate fi reparat ? Quote Link to comment Share on other sites More sharing options...
BUGHIU Posted July 4, 2014 Share Posted July 4, 2014 A doua varianta. Panglica!! Quote Link to comment Share on other sites More sharing options...
wlfu Posted July 4, 2014 Author Share Posted July 4, 2014 Problema cu aceasta panglica este ca nu face bine contact in mufa de pe placa electronica si se poate rezolva problema prin repozitionare ? Sau este dezlipita de pe sticla display-ului ? Multumesc anticipat pentru ajutor! Quote Link to comment Share on other sites More sharing options...
cluj1973 Posted July 5, 2014 Share Posted July 5, 2014 DISPLAY, caput,suta an suta aruncal la gunoi. Quote Link to comment Share on other sites More sharing options...
dan cod Posted July 5, 2014 Share Posted July 5, 2014 Asa zic si eu.Uita de tvul asta. Quote Link to comment Share on other sites More sharing options...
Join the conversation
