Guest marius4111 Posted June 30, 2014 Share Posted June 30, 2014 Buna seara! Am probleme cu un TV HYUNDAI HRH-2109 cu CI sursa CQO 765RT, procesor TDA11126PS/N3/3, traznit. Led rosu aprins, tensiune bara mare U=100V, nu porneste nici din telecomanda, nici din butoane, nu schiteaza nimic, final linii bun. Am schimbat CI sursa CQO 765RT era defect nu se aprindea nici ledul, condensatorii din sursa i-am scimbat. Va rog niste sfaturi si schema daca se poate. Multumesc! Quote Link to comment Share on other sites More sharing options...
bigbrother Posted June 30, 2014 Share Posted June 30, 2014 Sal, daca zici ca e traznit, in cel mai fericit caz ar fi memoria sau softul sau mai rau procesorul.Incearca cu o memorie goala, si masoara tensiunea pe ea daca e ok. Quote Link to comment Share on other sites More sharing options...
cristybadea Posted June 30, 2014 Share Posted June 30, 2014 In cazul asta nu prea cred sa fi scapat TDA-ul Quote Link to comment Share on other sites More sharing options...
bigbrother Posted June 30, 2014 Share Posted June 30, 2014 Da, daca vrei o schema cauta pe net LEKO TV-2165 pare asemanatoare la procesor.Eu o am dar are 1,5mb si max e de 500k. Quote Link to comment Share on other sites More sharing options...
Florinel TV Posted June 30, 2014 Share Posted June 30, 2014 schema asta ar trebui sa se potriveasca TDA11136 sursa5Q0765 verticalLA78041 sunetTDA2003.pdf Quote Link to comment Share on other sites More sharing options...
dan cod Posted July 1, 2014 Share Posted July 1, 2014 Tvurile traznite din pacate pot fi cu multe probleme.Trebuie masurati pinii de alimentare ai TDAului sa nu fie careva scurt la masa. Quote Link to comment Share on other sites More sharing options...
Guest marius4111 Posted July 9, 2014 Share Posted July 9, 2014 Vă multumesc . Încă nu am facut nimic la el că nu am avut timp.O sa revin cât mai curînd posibil. Quote Link to comment Share on other sites More sharing options...
Join the conversation
