tiptronic Posted June 23, 2014 Share Posted June 23, 2014 (edited) Servus, am salvat agenda dintr-un Nokia 302 in calculator, in Nokia Suite, si vreau sa o transfer intr-un HTC. E posibil? Si daca da, cum? Multumesc, Daniel Edited June 23, 2014 by tiptronic Quote Link to comment Share on other sites More sharing options...
morpheus05 Posted June 25, 2014 Share Posted June 25, 2014 Salut, Ar trebui sa fie posibil. Din Nokia Suite ii dai export la agenda intr-un format standard si din HTC ii faci import. Quote Link to comment Share on other sites More sharing options...
Matrixu Posted July 15, 2014 Share Posted July 15, 2014 In mod normal HTC-ul ar trebui sa stie sa importe un fisier de tip "txt" sau "vcf" Se exporta contactele de pe Nokia intr-un fisier si apoi se importa fisierul in agenda HTC. Quote Link to comment Share on other sites More sharing options...
Join the conversation
