vesenova Posted June 23, 2014 Share Posted June 23, 2014 La pornire televizorul incepe sa se restarteze de cateva ori singur! Dupa cca 1 min porneste si merge normal timp indelungat. De cateva zile restartarile sunt tot mai multe dar cand porneste merge iar normal. As dori, cine are experienta sa imi dea idee ce piesa ar putea face asa ceva si eventual ce etaj. Vreun electrolitic , cand se incalzeste merge bine? sau e vorba de vreun integrat? Multumesc! Quote Link to comment Share on other sites More sharing options...
Toni Marginean Posted June 23, 2014 Share Posted June 23, 2014 Trebuie schimbati condensatori electrolitici din sursa. De obicei se si vad care fiindca sunt curşi şi se vede ca placa acolo este mai inchisa la culoare. Quote Link to comment Share on other sites More sharing options...
leoncris Posted June 23, 2014 Share Posted June 23, 2014 Sasiu F 17. http://elektrotanya.com/nordmende_spectra_cv-63_cv-72_fss-chassis_f17-imc_imc2_sm.pdf/download.html Quote Link to comment Share on other sites More sharing options...
Join the conversation
