geopop Posted June 19, 2014 Share Posted June 19, 2014 buna! va rog sa ma ajutati la un lcd sharp ,lc-32D44E-BK ,placa baza qpwbxe449wjn.pleaca din stand-by,dar revine imediat.sursa functioneaza,are o memorie 4256bwp.e posibil softul?are cineva in caz,sa ma ajute?banuiesc ca ar fi eronat.multumesc ! Quote Link to comment Share on other sites More sharing options...
leoncris Posted June 19, 2014 Share Posted June 19, 2014 (edited) Verificasi ceva p'acolo , de te arunci direct la soft ? Ai incercat sa intrii in service mode ? http://www.toms-service-manuals.com/getfile.php?mode=viewpdf&req=Sharp_LC-32D44E_LC-32D44S_LC-32D44RU-BK_LC-32D44GY_[sM].pdf&mfg=Sharp Edited June 19, 2014 by leoncris Quote Link to comment Share on other sites More sharing options...
geopop Posted June 20, 2014 Author Share Posted June 20, 2014 am verificat tens bune 12v,5v ,52v pt invertor.pe placa baza memo e alim cand pleaca din stand-by cand apare tens3,3v,apoi intra din nou in st-by,nu se incalzeste nimic ,chiar de fortez alimentatrea printr-o comanda aux.am schimbat si memo dar acelasi fenomen,am pus una goala.vreo idee !multumesc! Quote Link to comment Share on other sites More sharing options...
leoncris Posted June 20, 2014 Share Posted June 20, 2014 "Ai incercat sa intrii in service mode ? " - sa vezi ce eroare afiseaza ? Quote Link to comment Share on other sites More sharing options...
dan cod Posted June 20, 2014 Share Posted June 20, 2014 Ce procesor are?cumva ceva VCT.....? Quote Link to comment Share on other sites More sharing options...
geopop Posted June 20, 2014 Author Share Posted June 20, 2014 procesor VCT7993P A1 HOOO ,in service mode se poate cu tv-ul in st-by ?cum ce cod se intra ? mersi ! Quote Link to comment Share on other sites More sharing options...
dan cod Posted June 20, 2014 Share Posted June 20, 2014 Se poate sa fie alterat softul din VCT. Quote Link to comment Share on other sites More sharing options...
geopop Posted June 20, 2014 Author Share Posted June 20, 2014 e posibil astfel ,tasta vol-,simultan cu INPUT<AV> apasate se introduce cablu alim in priza,tv ar trebui sa porneasca si ar aparea litera K pe ecran<deci menu service>,E posibil safie quartul procesorului ?MERSI! Quote Link to comment Share on other sites More sharing options...
leoncris Posted June 20, 2014 Share Posted June 20, 2014 Pai de ce'ti dadui manualul de service , sa intrebi de ... ori ? Quote Link to comment Share on other sites More sharing options...
Join the conversation
