geoky Posted June 18, 2014 Share Posted June 18, 2014 Sasiu Vestel 17MB25-1 / 17IPS15-3. La acest tv din cand in cand, la cateva zile,sau chiar de pe o zi pe alta, se reseteaza toate setarile de utilizator, si trebuiesc refacute, setare limba, cautare si memorare programe etc. Banuesc memoria sau softul alterat, daca are cineva un soft, il rog sa-l posteze. Multumesc ! Quote Link to comment Share on other sites More sharing options...
dan cod Posted June 18, 2014 Share Posted June 18, 2014 Vezi sursa prima data sa fie ok.Cu memoria e simplu.Cand e ok il opresti o citesti si scrii dumpul in alta memorie.Ar trebui sa fie pe soclu un 24C64. Quote Link to comment Share on other sites More sharing options...
geoky Posted June 30, 2014 Author Share Posted June 30, 2014 (edited) Verificat tensiuni sunt corecte, nu exita riplu, inlocuit memoria cu una noua , si alt soft,nici-un rezultat pozitiv.Daca mai are cineva vre-o idee ... Multumesc ! Edited June 30, 2014 by geoky Quote Link to comment Share on other sites More sharing options...
BUGHIU Posted June 30, 2014 Share Posted June 30, 2014 Vedeti si push butoanele de pe panou cum se prezinta?!?! Cine stie ;poate e din ele..... Quote Link to comment Share on other sites More sharing options...
geoky Posted June 30, 2014 Author Share Posted June 30, 2014 Au fost verificate primele, tastatura are un conector, si cu el scos la fel face. Quote Link to comment Share on other sites More sharing options...
Join the conversation
