gymy Posted June 16, 2014 Share Posted June 16, 2014 La televizorul din titlu se se blocheaza imagine face un fel de pauza imagine.Am observat ca driverul pentru display MST7610LB se incalzeste cam tare.Poate fi el cauza ?Tensiunile de 5 si 3,3 par ok. Quote Link to comment Share on other sites More sharing options...
leoncris Posted June 17, 2014 Share Posted June 17, 2014 Ia schema si treci la masuratori. http://elektrotanya.com/grundig_chassis_beko_lx.pdf/download.html Verifica sursa de 3,3V .Asta creeaza probleme la modelul asta. Quote Link to comment Share on other sites More sharing options...
Join the conversation
