Guest GNS Posted June 15, 2014 Share Posted June 15, 2014 (edited) Am reparat la un TV LCD modelul DUAL DLCD3221, echipat cu Sursa 17PV15-8, sasiu (placa Baza)-17MB15E 5, placa SUNET 17AMP03-1. Am nevoie de servicii de manualul al acestui Aparat, intrucat o mai incercat si altcineva sa-l repare. As vrea sa vad ce Componente originale sunt Sursa, dupa aceea vom Vedea ... Frumos multumesc! Edited June 15, 2014 by GNS Quote Link to comment Share on other sites More sharing options...
leoncris Posted June 15, 2014 Share Posted June 15, 2014 (edited) http://www.electronica-pt.com/esquema/func-fileinfo/18947/http://elektrotanya.com/vestel_chassis_17mb15e-5_sm.pdf/download.html Edited June 15, 2014 by leoncris Quote Link to comment Share on other sites More sharing options...
Join the conversation
