electronix_2006 Posted June 14, 2014 Share Posted June 14, 2014 Salut,am un TV Universum FT7132 cu sasiu Finlux5000 care se manifesta cu urmatorul defect:sunetul este bun,OSB este bun dar imaginea nu are luminozitate,posibil lipsa semnal luminanta.Am inlocuit TDA4565,TDA2579A si se manifesta la fel.Daca modifici lumina,culoare,contrast aceste functii sunt active dar imaginea este tot fara luminozitate,se vad doar culorile.Daca aveti un sfat si ma puteti ajuta pentru rezolvarea acestui defect. Quote Link to comment Share on other sites More sharing options...
dan cod Posted June 14, 2014 Share Posted June 14, 2014 Ce matrice RGB are.Poate e intrerupta linia de intarziere.Screenul e ok? Quote Link to comment Share on other sites More sharing options...
electronix_2006 Posted June 14, 2014 Author Share Posted June 14, 2014 (edited) Matricea este TDA4680,screenul este ok Edited June 14, 2014 by electronix_2006 Quote Link to comment Share on other sites More sharing options...
Florinel TV Posted June 14, 2014 Share Posted June 14, 2014 incearca cu un dump poatei alterat bafta Universum FT7132.rar Quote Link to comment Share on other sites More sharing options...
palcu ion Posted June 14, 2014 Share Posted June 14, 2014 mai e vorba si de tub,oare e bun? Quote Link to comment Share on other sites More sharing options...
Join the conversation
