doban Posted June 14, 2014 Share Posted June 14, 2014 Buna ziua stimati colegi.Rog pe cei cu experienta sa ma ajute in limita timpului disponibil in depanarea sursei FEL3237UA,a tv-ului Daewo DLP-32C3B.Sursa este cu STW20NM60.Dupa masuratori am gasit 5v care exista in rest nu am nici o tensiune. Pe schema sursei sunt trecute numai tensiunile de iesire.Va multumesc!! Quote Link to comment Share on other sites More sharing options...
doban Posted June 14, 2014 Author Share Posted June 14, 2014 La pornire ledul se aprindea cand rosu, cand verde si nimic altceva nu functiona. Quote Link to comment Share on other sites More sharing options...
Guest Posted June 14, 2014 Share Posted June 14, 2014 Pai pune o captura din schema numai cu sursa, sa alerg eu pe net dupa schema? Quote Link to comment Share on other sites More sharing options...
doban Posted June 14, 2014 Author Share Posted June 14, 2014 incerc acum E in format pdf si nu reusesc sa postez aici,domnule miticamy rog mult o adresa de email si va trimit acolo,multumesc. Quote Link to comment Share on other sites More sharing options...
dan cod Posted June 14, 2014 Share Posted June 14, 2014 Arhiveaza si merge sau urca pe un site de gazduire. Quote Link to comment Share on other sites More sharing options...
Guest Posted June 14, 2014 Share Posted June 14, 2014 Vad ca are releu, se aude acesta la comanda pornit? Quote Link to comment Share on other sites More sharing options...
doban Posted June 14, 2014 Author Share Posted June 14, 2014 (edited) Da asta este schema ,releul cupleaza odata la pornire apoi ledul de stand-by clipeste incontinu din verde in rosu.La oprirea tv-ului iar cupleaza si apoi se opreste tot.Nu am tensiune deloc pe condensatorul de C23 (pe schema mijloc sus) lipsesc tensiunile de 24v,29v si12v. Edited June 14, 2014 by doban Quote Link to comment Share on other sites More sharing options...
t_alex92 Posted June 14, 2014 Share Posted June 14, 2014 (edited) Pe C21 ai ceva? Se pare ca sunt 2 surse una mare si una mica. Tie iti merge doar sursa de stand by daca zici ca ai doar 5V. Daca nu ai nici o tensiune pe C21 ar putea fi integratul IC1 defect. Verifica deasemenea si Q1,D1 si RTA1. Edited June 14, 2014 by t_alex92 Quote Link to comment Share on other sites More sharing options...
dan cod Posted June 14, 2014 Share Posted June 14, 2014 Strapeaza releulk sa vezi merge sursa mare? Quote Link to comment Share on other sites More sharing options...
doban Posted June 14, 2014 Author Share Posted June 14, 2014 Nu am nici o tensiune pe c21 Am strapat domnule dan cod si a pornit sursa,au aparut toate tensiunile care lipseau Quote Link to comment Share on other sites More sharing options...
elmar Posted June 14, 2014 Share Posted June 14, 2014 Am strapat domnule dan cod si a pornit sursa,au aparut toate tensiunile care lipseau deci sursa e buna ...dar nu primea comanda on de la placa de baza...sau poate chiar pe partea de on/off e ceva defect!verificati rel1 ,Q4 si piesele inconjuratoare ...si daca sunt bune ,defectul e undeva pe placa de baza! Quote Link to comment Share on other sites More sharing options...
doban Posted June 14, 2014 Author Share Posted June 14, 2014 Multumesc mai revin maine,wekend placut pentru toata lumea!! Quote Link to comment Share on other sites More sharing options...
doban Posted June 15, 2014 Author Share Posted June 15, 2014 Buna ziua,cum am promis ,am revenit cu rezultate.Defectul gasit a fost condensatorul C30 din schema postata de domnul miticamy.Pe schema este trecut de 2200mf in realitate pe placa este de 220mf.Este gresit pe schema.Deci condensatorul masurat cu ESR metrul in loc de 0.6 am gasit ESR de 5.2,iar masurat cu capacimetrul in loc de 220mf am gasit 14.5mf.condensatorul defect este de marca G-LUXON la 105 grade .Dupa schimbare tv-ul functioneaza normal.Multumesc mult pentru ajutorul acordat.Cu stima. Quote Link to comment Share on other sites More sharing options...
Join the conversation
