t_alex92 Posted June 14, 2014 Share Posted June 14, 2014 Buna ziua! Am un TV NEI model E 2044R sasiu E5 la care am imagine desincronizata pe AV. Mentionez ca initial am avut baleajul vertical defect(tda3653). Ma poate ajuta cineva cu un sfat? O fi din procesor sau se poate regla sincronizarea din ceva semireglabile? Quote Link to comment Share on other sites More sharing options...
iuliantv Posted June 14, 2014 Share Posted June 14, 2014 verficati daca comutatorul av este alimentat tea2014 eventul schimbatil Quote Link to comment Share on other sites More sharing options...
dan-a2 Posted June 14, 2014 Share Posted June 14, 2014 Ce mufe sunt ? scart sau rca ? > refaceti si lipiturile ,, pe ele '' (eventual verificati si cu alt cablu ) !! Quote Link to comment Share on other sites More sharing options...
t_alex92 Posted June 14, 2014 Author Share Posted June 14, 2014 Doar Euroscart are.Lipiturile pe mufa sunt facute si cablul merge la alt TV, dar la fel face.. Modelul ce il am eu este fara tea 2014. Quote Link to comment Share on other sites More sharing options...
dan cod Posted June 14, 2014 Share Posted June 14, 2014 Nu am schema in fata dar E5 este cu jungla 8362.Nu cred ca are comutator AV .Pe TV merge bine? Quote Link to comment Share on other sites More sharing options...
t_alex92 Posted June 14, 2014 Author Share Posted June 14, 2014 Exact este cu jungla 8362 si comutator AV nu are. Nu am incercat pe TV pentru ca nu am cablu, dar duc undeva televizorul si il conectez pe TV sa vad daca merge. Quote Link to comment Share on other sites More sharing options...
dan cod Posted June 14, 2014 Share Posted June 14, 2014 Nu cumva sa fie jungla defecta acolo. Quote Link to comment Share on other sites More sharing options...
iuliantv Posted June 14, 2014 Share Posted June 14, 2014 personal m-am luat dupa aceasta schema pe care o aveam si am urcat-o aici si aceasta are comutator av Quote Link to comment Share on other sites More sharing options...
palcu ion Posted June 14, 2014 Share Posted June 14, 2014 defecta este jungla tda 8362,defect tipic Quote Link to comment Share on other sites More sharing options...
t_alex92 Posted June 15, 2014 Author Share Posted June 15, 2014 Va multumesc pentru raspunsuri, voi schimba tda 8362 si revin cu rezultatele. Quote Link to comment Share on other sites More sharing options...
Join the conversation
