dragutzzz_112 Posted June 12, 2014 Share Posted June 12, 2014 Problema TV HERU CTV 31910 sasiu P1470A03 (101212) A fost trasnit si are in sursa douo tranzistoare care a sarit ciob din ele. Ma puteti ajuta cu o schema, sau sa-mi spuneti si mie ce tranzistoare sunt alea? Quote Link to comment Share on other sites More sharing options...
santamihai Posted June 13, 2014 Share Posted June 13, 2014 http://www.elforum.info/topic/70344-chassis-p1470a03/ Quote Link to comment Share on other sites More sharing options...
palcu ion Posted June 13, 2014 Share Posted June 13, 2014 primul,tip bc este a1015 dar mai bine montezi a1013 iar al doilea,capsula tip bd, c3807 iar final 1802 Quote Link to comment Share on other sites More sharing options...
Guest vio1968 Posted June 25, 2014 Share Posted June 25, 2014 buna seara ,o problema am si eu cu acest model de tv am tensiuni mici in sec. u1.55v.tinde sa plece din st.by dar se opreste imediat ,sursa este cu strw6553a.o schema pentru modelul acesta ?multumesc. Quote Link to comment Share on other sites More sharing options...
Guest vio1968 Posted June 27, 2014 Share Posted June 27, 2014 buna seara ,o problema am si eu cu acest model de tv am tensiuni mici in sec. u1.55v.tinde sa plece din st.by dar se opreste imediat ,sursa este cu strw6553a.o schema pentru modelul acesta ?multumesc. Quote Link to comment Share on other sites More sharing options...
leoncris Posted June 27, 2014 Share Posted June 27, 2014 (edited) Ai aici tot ce'ti trebuie . http://www.filehost.ro/30649566/HISENSE_UOC_TOP_64_MONO_V0_6_CHASSIS_21RF08_TDA11105PS_TDA11135PS_STRW6553_CD78040_TFA980_pdf/ http://monitor.espec.ws/section1/topic154734.html http://archive.espec.ws/section1/file21297.html Edited June 27, 2014 by leoncris Quote Link to comment Share on other sites More sharing options...
MISTER BIG Posted June 27, 2014 Share Posted June 27, 2014 sursa trebuie verificata piesa cu piesa, sigur mai sunt si altele defecte ,diode ,optocuplor etc. Quote Link to comment Share on other sites More sharing options...
Join the conversation
