Guest Andrei Catalin Posted June 12, 2014 Share Posted June 12, 2014 Salut! Am si eu o problema cu un minisistem SONY mai vechiut.Are momente cand il pornesc si nu se aude una din boxe(poate fi stanga sau dreapta)insa are momente cand dupa vreo cateva secunde incep sa se auda amandoua...alte dati chiar daca se aud amandoua are un effect foarte ciudat...ca acela de hall.Modelul sistemului este chc-tb10 si nu mi-a mai facut probleme pana acum...il folosesc de obicei pe radio...multumesc anticipat celor care imi raspund! Quote Link to comment Share on other sites More sharing options...
Guest Andrei Catalin Posted June 13, 2014 Share Posted June 13, 2014 Nu are nimeni nicio parere legata de problema mea? Quote Link to comment Share on other sites More sharing options...
leoncris Posted June 13, 2014 Share Posted June 13, 2014 Probleme legate de touch butoanele din panou , cred. Quote Link to comment Share on other sites More sharing options...
Emil 1986 Posted June 13, 2014 Share Posted June 13, 2014 verificati daca face contact bine firul gnd de la dif sau daca este lipitura rece la mufa pe partea de gnd Quote Link to comment Share on other sites More sharing options...
Join the conversation
