augustin Posted June 12, 2014 Share Posted June 12, 2014 Sanatate !! Porneste cu sunet normal dar lipsa imagine .. Pe dispay apar linii subtiri verticale care isi schimba pozitia , uneori imaginea se albeste tot mai tare , alteori apare si imaginea dar tremura , sau ramane blocata ca si cand ar fi pe pauza .. OSD apare uneori dar isi schiba locatia ... Dupa cateva minute isi revine si functioneaza perfect ... Condensatori unflati nu am gasit ... cei din sursa iam schimbat toti . de pe placa logica iam schimbat pe cei de pe stabilizatoare , dar fara efect ...Ce ar putea produce acest defect , Mai ales ca dupa un timp isi revine si functioneaza perfect ? ... Multumesc !! Quote Link to comment Share on other sites More sharing options...
iod2 Posted June 12, 2014 Share Posted June 12, 2014 ecranul cu trasee intrerupte........ Quote Link to comment Share on other sites More sharing options...
dan cod Posted June 12, 2014 Share Posted June 12, 2014 Ce tip de display are? Quote Link to comment Share on other sites More sharing options...
augustin Posted June 12, 2014 Author Share Posted June 12, 2014 Display-ul este : Sharp LK315T3LZ94 Quote Link to comment Share on other sites More sharing options...
cianyika Posted June 12, 2014 Share Posted June 12, 2014 In partea dreapta sus cum te uiti din fata ai trasee intrerupte si sunt foarte greu reparat.Pune o bucata de guma ce se foloseste pentru racire la radiatoare sub tabla sa il tina apasat. E singura sansa de reparatie. E boala la modelua asta de panel sharp Quote Link to comment Share on other sites More sharing options...
Join the conversation
