Guest kidd009 Posted June 12, 2014 Share Posted June 12, 2014 Salutare! O problema cu un TV Philips, a fost conectat pe post de tv, l.am oprit..apoi am vrut sa il conectez la pc, sa vad un film..dar nu se mai aprinde...ledul e rosu, cand dau sa il pornesc, se face alb, pt o secunda, apoi se stinge..in tot acest timp displayul ramane negru...si are si un "tiuit" usor in continuu...Ceva idei? Quote Link to comment Share on other sites More sharing options...
leoncris Posted June 12, 2014 Share Posted June 12, 2014 Philips si ... mai cum ? Sursa , invertor , CCFL_uri ..................... Quote Link to comment Share on other sites More sharing options...
dan cod Posted June 12, 2014 Share Posted June 12, 2014 Sursa este primul suspect. Quote Link to comment Share on other sites More sharing options...
Guest kidd009 Posted June 12, 2014 Share Posted June 12, 2014 Si unde gasesc eu detalii despre invertor..si ccfl (habar nu am ce inseamna)..? Quote Link to comment Share on other sites More sharing options...
stefank Posted June 12, 2014 Share Posted June 12, 2014 detalii va gasi depanatorul la care vei duce televizorul la reparat Quote Link to comment Share on other sites More sharing options...
Join the conversation
