SEBYKO_76 Posted June 10, 2014 Share Posted June 10, 2014 (edited) Buna ziua tuturor.. Tv Pacific, model PTV 5102, sasiu CTS-AA, la iesirea din st-by pare ca pleca inalta, dar ceva se intampla.. Nu am filament si tubul nu se lumineaza.. Verific tensiunea pe bara principala am 110 V, pare in regula...Verific tensiunea de alimentare a driverului, in sarea OFF am 105V, iar in ON tensiunea cade pe rezistenta din colectorul lui, respectiv 3444....Oare ce-mi scapa, ma poate ajuta cineva?? A mai intalnit cineva un astfel de defect la acest tip de tv?? Mentionez ca am schimbat c-urile de pe bara de +, am verificat finalul linii si driverul nu sunt defecte......Acesta este schema cu modul de linii..Multumesc. Schema Pacific.doc Edited June 10, 2014 by SEBYKO_76 Quote Link to comment Share on other sites More sharing options...
SEBYKO_76 Posted June 10, 2014 Author Share Posted June 10, 2014 (edited) Am verificat iesirea HOUT pinul 48 a junglei STV 2246 am 0.9 V cred ca este cam mare.....Posibil din acest motiv sa blocheze tranzistorul "driver".... Edited June 10, 2014 by SEBYKO_76 Quote Link to comment Share on other sites More sharing options...
tehtronics Posted June 10, 2014 Share Posted June 10, 2014 cat ai, exact, tensiunea +5STB ? Quote Link to comment Share on other sites More sharing options...
iuliantv Posted June 10, 2014 Share Posted June 10, 2014 posibil chiar baleaj vertical defect Quote Link to comment Share on other sites More sharing options...
dan cod Posted June 11, 2014 Share Posted June 11, 2014 Prima problema care trebuie lamurita este daca chiar pleaca inalta sau pleaca doar o fractiune de secunda.Ai ceva recuperate din linii? Quote Link to comment Share on other sites More sharing options...
SEBYKO_76 Posted June 21, 2014 Author Share Posted June 21, 2014 (edited) Buna ziua...revin cu detalii ..Am verificat daca exista ceva "recuperate" la trafo linii, se pare ca exista o tensiune de 156 V(de fapt trebuia sa fie de 200V) pentru finalul video, chiar si FIT este (se aude in trafo linii acel sfârâit specific)... Tensinea de +5V STBY este 4,6V... Edited June 21, 2014 by SEBYKO_76 Quote Link to comment Share on other sites More sharing options...
dan cod Posted June 21, 2014 Share Posted June 21, 2014 Cei 136V nu e tensiune recuperata ci U1 care se regaseste acolo din cauza ca infasurarea este impreuna cu cea de U1.Clar ca liniile nu merg acolo. Quote Link to comment Share on other sites More sharing options...
tehtronics Posted June 21, 2014 Share Posted June 21, 2014 (edited) unul dintre tz. 7577 si 7575 sunt compromisi Inlocuieste-i pe ambii cu BC337 Schimba si C-ul 2564(220uF) Edited June 21, 2014 by tehtronics Quote Link to comment Share on other sites More sharing options...
SEBYKO_76 Posted June 21, 2014 Author Share Posted June 21, 2014 (edited) Am verificat cele 2 tranzistoare, sunt ok, am inlocuit si C2654,,,fara rezultat. Mda se pare ca am gasit defectul...BV, TDA 1771.... defect scurt la pinul 1..... OUT si masa...Revin cu detalii dupa ce il inlocuiesc...Stima Edited June 21, 2014 by SEBYKO_76 Quote Link to comment Share on other sites More sharing options...
palcu ion Posted June 21, 2014 Share Posted June 21, 2014 Buna ziua...revin cu detalii ..Am verificat daca exista ceva "recuperate" la trafo linii, se pare ca exista o tensiune de 156 V(de fapt trebuia sa fie de 200V) pentru finalul video, chiar si FIT este (se aude in trafo linii acel sfârâit specific)... Tensinea de +5V STBY este 4,6V... si n-ai descoperit alimentarea bv? Quote Link to comment Share on other sites More sharing options...
Join the conversation
