nicuschiopu Posted June 10, 2014 Share Posted June 10, 2014 (edited) acest sasiu este echipat cu :procesor PCA84C641/068S1 memorie 24C02 jungla TDA8362 defectul este urmator nu mai memoreaza programe daca ma puteti ajuta cu ceva solutii va multumesc. Edited June 10, 2014 by nicuschiopu Quote Link to comment Share on other sites More sharing options...
leoncris Posted June 10, 2014 Share Posted June 10, 2014 (edited) Sasiu E5. Daca toate tensiunile sunt OK , posibil bin ... alterat. http://www.filesharing.md/download.php?id=730b943b50326d50c502160cee8cdd6a Edited June 10, 2014 by leoncris Quote Link to comment Share on other sites More sharing options...
nicuschiopu Posted June 10, 2014 Author Share Posted June 10, 2014 am scris alta memorie aceiasi problema poate fi procesorul defect ca nu schimba nici canale nu pot trece pe alt program blocat pe un singur canal daca mai sunt ceva solutii postatile va rog va multumesc. Quote Link to comment Share on other sites More sharing options...
dan cod Posted June 10, 2014 Share Posted June 10, 2014 Asta merge cu memorie goala.Memorarea se face cu store -nr program-store.Nici asa nu tine minte?Sau nu cumva este dereglat CAFul si fuge de pe post?Se opreste pe post la cautare? Quote Link to comment Share on other sites More sharing options...
nicuschiopu Posted June 10, 2014 Author Share Posted June 10, 2014 (edited) nu fuge de pe post daca fac cautare si am gasit un program dau memorare afiseaza cifrele cand dau memorare apare CLEAR (store) dar nu se face verde ca si cum ar memora apare sus in dreapta ecranului un (-)dupa ce apas clear drept dovada ca nu ramane cifra aferenta programului respectiv daca ma mai puteti ajuta cu ceva solutii va multumesc. Edited June 10, 2014 by nicuschiopu Quote Link to comment Share on other sites More sharing options...
dan cod Posted June 10, 2014 Share Posted June 10, 2014 CLEAR este stergere nu memorare STORE este memorare.Cred ca gresesti aici.Apesi store din telecomanda(tasta Mdaca este telecomanda originala de E5) apare store scris cu rosu apoi dai numarul pe care vrei sa memorezi si apoi apesi iar store .Atunci STORE trece din rosu in verde si inseamna ca ai memorat programul. Quote Link to comment Share on other sites More sharing options...
nicuschiopu Posted June 10, 2014 Author Share Posted June 10, 2014 (edited) nu are telecomanda din butoanele de pe panou de ce nu pot memora ,ca afiseaza caracterele nu ar trebui sa pot memora si cu butoanele de pe panoul tv-lui? Edited June 10, 2014 by nicuschiopu Quote Link to comment Share on other sites More sharing options...
dan cod Posted June 10, 2014 Share Posted June 10, 2014 Eu stiu ca E5 nu are tasta store pe panou.Daca o are si la apasare apare store atunci merge si din panou. Quote Link to comment Share on other sites More sharing options...
nicuschiopu Posted June 10, 2014 Author Share Posted June 10, 2014 cer scuze nu are store ,am luat o telecomanda E5 am dat cautare si in momentul cand apas store dispare caraterul store si nu memoreaza nu mai inteleg nimic cu aceste defecte ciudate mai sunt solutii va rog postatile. Quote Link to comment Share on other sites More sharing options...
nicuschiopu Posted June 10, 2014 Author Share Posted June 10, 2014 se poate inchide am rezolvat problema era intrerupt un traseu de la un pin al memoriei am refacut lipitura si memoreaza totul e ok va multumesc pentru solutii. Quote Link to comment Share on other sites More sharing options...
Join the conversation
