floring69 Posted April 26, 2014 Share Posted April 26, 2014 Buna dimineata! Clientul nu stie provenienta televizorului dar ma asigura ca el a functionat candva. Se pare ca a fost nefolosit ani de zile. Imaginea este perfecta. Insa, daca dau mai tare se aude un pacanit in difuzor in functie de cum avanseaza cursorul de sunet pe imagine. Daca il dau la minim dispare si pacanitul. Cand schimb programele se aude acelasi tip de pacanit. In difuzor se aude zgomot de fond, un fashait. Am schimbat integratul de sunet, memoria dar fara succes. Apreciez orice alte idei. Va multumesc! sasiu 11AK19B-1 Quote Link to comment Share on other sites More sharing options...
dan cod Posted April 26, 2014 Share Posted April 26, 2014 Este stereo sau mono?Norma de sunet e setata corect? Quote Link to comment Share on other sites More sharing options...
floring69 Posted April 26, 2014 Author Share Posted April 26, 2014 Este stereo sau mono?Norma de sunet e setata corect? Da, este stereo. Norma de sunet este setata corect. Am incercat toate normele, nu "simte" nimic. Quote Link to comment Share on other sites More sharing options...
neculavasile Posted April 26, 2014 Share Posted April 26, 2014 ai verificat condi din jurul etaj sunet ,filtrajul pe alimentare? Quote Link to comment Share on other sites More sharing options...
floring69 Posted April 26, 2014 Author Share Posted April 26, 2014 (edited) ai verificat condi din jurul etaj sunet ,filtrajul pe alimentare? Verificat si inlocuiti... dar, teoretic cred ca beleaua este inaintea etajului de sunet. Pe intrare bazaie daca pun o surubelnita metalica. Ma gandesc ca nu iese ceva corect din jungla. Edited April 26, 2014 by floring69 Quote Link to comment Share on other sites More sharing options...
dan-a2 Posted April 26, 2014 Share Posted April 26, 2014 Schimba de proba si quartz-ul de langa procesorul de sunet (MSP ) Quote Link to comment Share on other sites More sharing options...
Join the conversation
