gaguady Posted April 25, 2014 Share Posted April 25, 2014 Saluatare tuturor. Hristos a inviat! Am si eu un TV Samsung CK 5342AT, sasiu P68SA, caruia ii este distorsionata imagunea pe anumite canale, iar pe alte canale, timp de 10 sec, imaginea e clara, apoi se distorsioneaza, mai ales scrisul nu se mai intelege. Am schimbat si posistorul pt ca era plesnita carcass lui, iar prin c-uri nu este nici unul unflat! Daca cineva a mai intalnit problema asta, va rog sa ma deslusiti si pe mine. Multumesc anticipat. Quote Link to comment Share on other sites More sharing options...
mariantoader82 Posted April 25, 2014 Share Posted April 25, 2014 (edited) Rotiti USOR invers sensului acelor de ceasornic un sfert de tura din bobina caf succes. Edited April 25, 2014 by mariantoader82 Quote Link to comment Share on other sites More sharing options...
mercenarx Posted April 25, 2014 Share Posted April 25, 2014 sau verificat stabilitatea zener 33 volti in timp... o alta cauza ar putea fi chiar selectorul. Quote Link to comment Share on other sites More sharing options...
palcu ion Posted April 25, 2014 Share Posted April 25, 2014 bobina de caf t 101 este usor dezacordata,cred ca este intre pinii 1-2 la tda 8362,sper sa nu fi gresit schema Quote Link to comment Share on other sites More sharing options...
gaguady Posted April 26, 2014 Author Share Posted April 26, 2014 Problema era intradevar din bobina de caf - T104 -. Va multumesc pentru sfaturi. Sanatate. Quote Link to comment Share on other sites More sharing options...
Join the conversation
