Guest dan_ro28 Posted April 25, 2014 Share Posted April 25, 2014 am un player philips montat pe masina (cel din fabrica) si nu imi mai primeste cd-ul. cand bag cd mi-l scoate imediat afara si imi da error cd. am incercat cu mai multe tipuri de cd-uri si acelasi lucru face. playerul functioneaza...dar acum doar radio merge atat. o parere cam ce as putea sa ii fac in afara de a-l arunca .....am unul functional de la sony dar daca il schimb pierd comenzile de volan si afisajul iar ca sa ii iau mufe adaptoare la sony pt comenzi si afisaj costa cam mult. Quote Link to comment Share on other sites More sharing options...
doru700 Posted April 25, 2014 Share Posted April 25, 2014 sterge lentila cu un betisor de urechi .(trebuie scos din bord )sigur are praf.. Quote Link to comment Share on other sites More sharing options...
Guest dan_ro28 Posted April 25, 2014 Share Posted April 25, 2014 daca se curata isi revine? Quote Link to comment Share on other sites More sharing options...
dan cod Posted April 26, 2014 Share Posted April 26, 2014 Nu neaparat.Bine era daca spuneai ce aparat este.CDR500 sau 2500 de VDO? Quote Link to comment Share on other sites More sharing options...
Guest dan_ro28 Posted July 23, 2014 Share Posted July 23, 2014 am demontat cd playerul si am vazut ca este radiosat 6000 philips by renault cum pot sa ii trag aux? la spate are trei mufe una pt afisaj ingusta si doua cu pini normale. are si plasticul pentru a patra dar fara pini Quote Link to comment Share on other sites More sharing options...
dan cod Posted July 25, 2014 Share Posted July 25, 2014 Pune ceva poze cu mecanica de cd.Poate se poate repara. Quote Link to comment Share on other sites More sharing options...
Guest dan_ro28 Posted July 25, 2014 Share Posted July 25, 2014 l-am demontat ial la capul de redare e deslipita mufa principala si 8 trasee sunt stricate. as vrea totusi sa ii trag aux ca si asa la cd nu il folosesc ca nu citeste mp3.ma puteti ajuta cu aux? Quote Link to comment Share on other sites More sharing options...
Guest dan_ro28 Posted July 29, 2014 Share Posted July 29, 2014 o idee de montaj aux? Quote Link to comment Share on other sites More sharing options...
madcox Posted July 29, 2014 Share Posted July 29, 2014 Eu la un cd-player de Ford am montat intrare de auxiliar lipind trei fire ( ptr jack stereo ) pe L-out, R-out si pe Gnd. La cd-player-ul respectiv pinii erau notati ca atare, asadar nu a fost problema cu gasirea lor. Vezi daca gasesti si tu pe placa iesirile respective si leaga-te de ele. Ca sa mearga totusi auxuliarul trebuie facut un cd cu "liniste" care va rula insa sunetul va fi din dispozitivul tau ( mp3 player, telefon, etc ). Pune o poza si cu spatele placii cu circuite. Poate te ajuta: http://forum.clubford.ro/viewtopic.php?f=20&t=52271&p=1376810#p1376810 Quote Link to comment Share on other sites More sharing options...
Guest dan_ro28 Posted July 29, 2014 Share Posted July 29, 2014 ar fi o metoda dar nu si in cazul meu intrucat nu imi mai merge cd-ul. Quote Link to comment Share on other sites More sharing options...
dan cod Posted August 4, 2014 Share Posted August 4, 2014 Sa mearga si cdul nu ai cum reziova fara un comutator mecanic. Quote Link to comment Share on other sites More sharing options...
Guest dan_ro28 Posted August 4, 2014 Share Posted August 4, 2014 nu ma intereseaza cd-ul.daca pot sa inlocuiesc mecanismul cd cu un mp3 player sau altceva ar fi bine Quote Link to comment Share on other sites More sharing options...
validae Posted August 4, 2014 Share Posted August 4, 2014 Decât să te complici, mai bine dai 15 lei şi iei un modulator FM că unele au şi intrare semnal auxiliar.Bănuiesc că radioul îţi merge Quote Link to comment Share on other sites More sharing options...
Guest dan_ro28 Posted August 4, 2014 Share Posted August 4, 2014 calitatea sunetului la modulator nu prea e buna. in plus tii ocupata si briceta pentru el si mai si incomodeaza dispozitivul iar iesirea de aux de la modulator nu ma ajuta cu nimic ca eu la cd player nu am aux. Quote Link to comment Share on other sites More sharing options...
validae Posted August 4, 2014 Share Posted August 4, 2014 Poţi încerca să injectezi semnal dintr'o sursă externă (mp3 player de ex.) pe traseul audio, dar e foarte probabil ca selectorul de cale audio să nu fie activat atunci când cd playerul nu recunoaşte discul. Nu strică să încerci totuşi, cu grijă, având semnalul audio decuplat cu un condensator de 1uF minimum.Dai playerul pe cd şi dai cu semnalul audio pe pinii de ieşire ai integratului selector de cale. Va trebui să identifici singur care e acela căutând pe Google după numele integratelor de pe placă. Quote Link to comment Share on other sites More sharing options...
Join the conversation
