emy_dx Posted April 24, 2014 Share Posted April 24, 2014 Va salut. Masina asta de spalat imi da batai de cap,aseara dupa ce i-am dat reset ca sa o programez la alt program a inceput sa imi dea eroare F23.Daca apas reset imi pleaca de la evacuare si sta pana se aprinde ledul ''curatati pompa''am inspectat pompa nu are nimic in ea,daca pun apa in cuva manual scoate apa,am verificat presostatul,rezistenta incalzire,senzorul de temperatura,nu am gasit nimic defect. Ma gandesc sa scriu softul,are cineva soft pentru ea? Va multumesc anticipat. Quote Link to comment Share on other sites More sharing options...
emy_dx Posted April 25, 2014 Author Share Posted April 25, 2014 Am desfacut presostatul,curatat,reglat si acum vad ca merge,oricum o sa-i cumpar unul nou. Sper sa foloseasca si la altcineva rezolvarea asta. Quote Link to comment Share on other sites More sharing options...
Join the conversation
