csongore Posted April 22, 2014 Share Posted April 22, 2014 Am un televizor SCHNAIDER SRF2108T A avut ars redresorul din primar si mos-fet ul,tranzistorul din linii pare OK n-am gasit condensatoare sau diode in scurt pe partea secundara. Am schimbat mosfetul+rezistentele de putere pentru masurarea curentului dar scurtul persista, integratul(MC44608P40)+traful din SMPS nu am putut sa verific. Nici schema nu am gasit pe net daca aveti ceva ideii?Cu stima! Quote Link to comment Share on other sites More sharing options...
misuraelectronic Posted April 22, 2014 Share Posted April 22, 2014 Am un televizor SCHNAIDER SRF2108T1-- amice , scrie naibii corect romaneste ! acest tvc se numeste SCHNEIDER , nicidecum SCHNAIDER .2-- modelul srf2108t s-a fabricat pe 2 sasie diferite , cumparate de la firma BEKO , anume 14.2 sau 16.1 Quote Link to comment Share on other sites More sharing options...
dan cod Posted April 22, 2014 Share Posted April 22, 2014 Cu ce-i facuta sursa asta?ce CI are in primar?Scurtul unde este pe alternativ sau pe continuu? Quote Link to comment Share on other sites More sharing options...
csongore Posted April 22, 2014 Author Share Posted April 22, 2014 Scuze m-am grabit. am versiunea 14.2Integratul e MC44608P40 poate fi el vinovat alte piese defecte n-am gasitAm schimbat-Siguranta-Redresorul de retea-NTC-MOS-Fet-Rezistentta de puere 0.22RDefectul persista in secundarul pare OK Quote Link to comment Share on other sites More sharing options...
dan cod Posted April 22, 2014 Share Posted April 22, 2014 De ce nu raspunzi la intrebare?ce este scurt?pe continuu pe 300V?pe alternativ?.MCul sigur nu iti da scurt. Quote Link to comment Share on other sites More sharing options...
Toni Marginean Posted April 22, 2014 Share Posted April 22, 2014 La cate s-au stricat putin probabil ca MC44608P40 sa fi scapat! Deci schimbati-l. Quote Link to comment Share on other sites More sharing options...
csongore Posted April 22, 2014 Author Share Posted April 22, 2014 Da integratul era de vina nu ma gandeam ca sunt asa sensibile Multumesc pentu toti!! icon_jook Quote Link to comment Share on other sites More sharing options...
Join the conversation
