robert1000 Posted April 16, 2014 Share Posted April 16, 2014 Tv-ul din titlu, are sunet bun, prezinta linie orizontala pe mijlocul ecranului, defect tipic BV la7848.....insa linia orizontala nu vine de la un capat la celalalt al ecranului, numai pe 60-70% din ecran.Poate sa mai fie ceva?Problema mea este acum unde gasesti un la7848 in Bucuresti, bun.....are careva de pe forum, zona berceni? Quote Link to comment Share on other sites More sharing options...
Radiotelegrafist Posted April 16, 2014 Share Posted April 16, 2014 gasesti pe maica domnului sunt enspemii de magazine Quote Link to comment Share on other sites More sharing options...
dan cod Posted April 16, 2014 Share Posted April 16, 2014 LA7848 face si EW de aceea dunga nu e pana la margine.vezi sa schimbi si conzii in zona ca altfel degeaba il schimbi. Quote Link to comment Share on other sites More sharing options...
robert1000 Posted April 16, 2014 Author Share Posted April 16, 2014 Cu siguranta domnule Dan, intotdeauna ii schimb.Mi-e un pic frica sa nu fie si jungla, cum se mai intampla la aceasta capodopera de tv.O sa caut pe Maica Domnului atunci.Multumesc, o sa revin dupa schimbare ic si conzi. Quote Link to comment Share on other sites More sharing options...
robert1000 Posted April 16, 2014 Author Share Posted April 16, 2014 L-am desfacut, si am observat c-a mai fost reparat o data, inlocuit ic vertical si condul pe alimentare.... ic-ul e strapuns, se vede gaurit.De ce oare, nu stiu... Quote Link to comment Share on other sites More sharing options...
dan cod Posted April 16, 2014 Share Posted April 16, 2014 In general din cauza conzilor pusca asa.Daca nu ai ghinionul sa fie deflexia dusa dar asta mai rar. Quote Link to comment Share on other sites More sharing options...
dan-a2 Posted April 16, 2014 Share Posted April 16, 2014 Schimbati C 310 si C419 !! Quote Link to comment Share on other sites More sharing options...
robert1000 Posted April 16, 2014 Author Share Posted April 16, 2014 Vi se intampla des sa vina inapoi proprietarii de tv daewoo slim cu IC BV defect recent dupa inlocuire? Quote Link to comment Share on other sites More sharing options...
dan cod Posted April 16, 2014 Share Posted April 16, 2014 Nu stiu sa fi avut vreu retur.Deci nu. Quote Link to comment Share on other sites More sharing options...
robert1000 Posted April 18, 2014 Author Share Posted April 18, 2014 Am schimbat la7848, conzii din zona BV, si tot apare linia orizontala, acum insa de la un capat la celalalt al ecranului.Ce sa fie dragilor, ca m-a innebunit tv-ul astaUn sfat va rog Quote Link to comment Share on other sites More sharing options...
dan cod Posted April 18, 2014 Share Posted April 18, 2014 Poate ai nimerit un stift de CI Quote Link to comment Share on other sites More sharing options...
robert1000 Posted April 18, 2014 Author Share Posted April 18, 2014 L-am luat de la sonic s.r.l. Astia au stifturi?Inca ceva : poate sa fie bobina de deflexie defecta? Am un tub de monitor de 17". Pot sa probez sasiul pe el, sa vad daca apare imagine pe ecran? Quote Link to comment Share on other sites More sharing options...
robert1000 Posted April 18, 2014 Author Share Posted April 18, 2014 Am incercat cu alt CI cadre si tot imi apare dunga orizontala.Pe sasiu vad c-au mai fost refacute lipituri in zona cadre, mufa deflexie.Cum pot vedea daca e defecta bobina de deflexie? Pot proba sasiul pe un tub de monitor plat? Sau nu merge??Un raspuns va rog frumos Quote Link to comment Share on other sites More sharing options...
robert1000 Posted April 18, 2014 Author Share Posted April 18, 2014 Dupa ce am studiat mai bine defectul, am gasit o rezistenta de 100ohmi arsa/carbonizata, pe traseul ce face legatura intre pin 108 EWD/AVL procesor si pin 5 CI cadre (V IN- )Am inlocuit-o dar nu s-a rezolvat nimic.Ma gandesc ca e procesorul defect pe partea de BV.Stie careva cum pot recupera procesorul pentru semnal BV? Quote Link to comment Share on other sites More sharing options...
dan cod Posted April 18, 2014 Share Posted April 18, 2014 Daca e defect nu ai cum sa il recuperezi. Quote Link to comment Share on other sites More sharing options...
Join the conversation
