electrod90 Posted April 15, 2014 Share Posted April 15, 2014 Salut. am un tv Samsung LE32S86BD si de o luna de zile la pornire distorsioneza foarte tare sunetul circa 20 30 sec.. dupa care isi revine si merge perfect ... precizez am schimbat condensatori electrolitici in sursa umflati si devalorizati insa tv-ul functiona la fel si cu cei defecti. .. ce ma sfatuiti Quote Link to comment Share on other sites More sharing options...
Gabriel_S Posted April 15, 2014 Share Posted April 15, 2014 aveti niste condensatori electrolitici pe mb sub o protectie metalica... Quote Link to comment Share on other sites More sharing options...
Guest Posted April 15, 2014 Share Posted April 15, 2014 aveti niste condensatori electrolitici pe mb sub o protectie metalica...Adica aveti niste condensatori format SMD pe placa de baza devalorizati si/sau cu esr marit. Quote Link to comment Share on other sites More sharing options...
Join the conversation
