alexdaniel Posted April 15, 2014 Share Posted April 15, 2014 Salut.Am acest tv cu urmatorul defect nu am inalta tensiune bu este bun tensiunile sunt bune am masurat condesatorii sunt buni unde ar trebui sa caut.Multumesc. Quote Link to comment Share on other sites More sharing options...
BUGHIU Posted April 15, 2014 Share Posted April 15, 2014 Ce sasiu? 11ak30? Schimbati condi C619(100NF/250V). Quote Link to comment Share on other sites More sharing options...
Meta-fizica Posted April 15, 2014 Share Posted April 15, 2014 Ai comanda in baza BU ?Teletech si mai cum ? Quote Link to comment Share on other sites More sharing options...
alexdaniel Posted April 15, 2014 Author Share Posted April 15, 2014 E sasiu 11ak30 amschimbat condesatorul si la fel e. Quote Link to comment Share on other sites More sharing options...
dan cod Posted April 15, 2014 Share Posted April 15, 2014 Ledul cum este verde sau ro?Condul C619 e foarte pretentios daca are sub 98nF pa pornire linii. Quote Link to comment Share on other sites More sharing options...
alexdaniel Posted April 15, 2014 Author Share Posted April 15, 2014 E rosu in stby cind se deschide se stinge am sunet dar nu am imagine nu am inalta si condesatorul este de 100nf\250v. Quote Link to comment Share on other sites More sharing options...
dan cod Posted April 15, 2014 Share Posted April 15, 2014 Pai cand pleaca dinstby ledul trebuie ca din rosu sa se faca verde.Apoi eu stiu ca ,condul ala este de 100nF/250V dar chiar are sigur atata?(l-ai masurat sau asa scrie pe el si o iei de buna/)pune un 22nF peste el sa vezi pleaca TVul? Quote Link to comment Share on other sites More sharing options...
Florinel TV Posted April 15, 2014 Share Posted April 15, 2014 mai verifica r640 2k7 smd sa nu fie intrerupta Quote Link to comment Share on other sites More sharing options...
alexdaniel Posted April 18, 2014 Author Share Posted April 18, 2014 Iam schimbat c619 100nf\250v si da sa porneasca dar face un ticait citeva secunde in traf linie si intra ear in stby ca si cum ar fi dus bu dar e bun e posibil sa fie traf linie? Quote Link to comment Share on other sites More sharing options...
santamihai Posted April 18, 2014 Share Posted April 18, 2014 Tensiunea de 8V cum este ? Quote Link to comment Share on other sites More sharing options...
alexdaniel Posted April 18, 2014 Author Share Posted April 18, 2014 8v este ok tensiunile sunt bune Quote Link to comment Share on other sites More sharing options...
santamihai Posted April 18, 2014 Share Posted April 18, 2014 Ati verificat la defecte tipice 11AK30 ?TV-ul pleaca din stand by si imediat pica in stand by, ledul trece din rosu in verde si revine pe rosu.Valoarea tensiunii pe pinul 52 procesor nu se stabilizeaza ca valoare intre 1.2v si 2.4v, cauze:- tensiunea +5v incorecta- tensiunea +8v incorecta- valoare incorecta sau consum marit pe B+ (115v) sesizata prin protectia electronica- tensiune FIT maritaSe deconecteaza trafo linii prin intreruperea circuitului tensiunii B+ anulandu-se 2 cauze care actioneaza asupra pinului 52 de protectie procesor.Se va verifica bara de B+ prin conectarea unei sarcinii artificiale bec de 220v/110w(se poate folosii si o rezistenta de putere) si se va conecta dupa al doilea filtraj de pe B+(dupa siguranta electronica). Daca se porneste TV-ul si becul se aprinde iar ledul ramane pe verde atunci tensiunea B+ este ok, daca nu se vor schimba condensatorii de filtraj. Se va verifica de asemenea actionarea sigurantei electronice prin prezenta tensiunii de 3-4v pe anodul diodei d510 din pinul 52 procesor.-consum marit pe etajul final linii, cauze bu808 defect sau scurt pe tensiunile recuperate din trafo linii sau chiar trafo linii defect. Quote Link to comment Share on other sites More sharing options...
alexdaniel Posted April 18, 2014 Author Share Posted April 18, 2014 Deci ledul pe stby este rosu cind se deschide tvul se stinge nu se face verde.Daca ii scot c619 100nf\250v am sunet dar nu am imagine. Quote Link to comment Share on other sites More sharing options...
cristybadea Posted April 19, 2014 Share Posted April 19, 2014 Posibil integrat bv defect(scurt pe alimentare).Verificati in momentul cand led-ul se stinge dupa comanda on daca aveti 5v dupa IC 806.succes! Quote Link to comment Share on other sites More sharing options...
alexdaniel Posted April 19, 2014 Author Share Posted April 19, 2014 In locul trafului 11425111A A04 merge schimbat cu JF0501-19238 este tot de la un sasiu 11ak30? Quote Link to comment Share on other sites More sharing options...
Join the conversation
