tanase Posted April 13, 2014 Share Posted April 13, 2014 am acest tv la reparat,porneste pe un canal iar in stanga sus apare M A1114 si nu mai primeste nici o comanda ,am banuit ca are memoria defecta si neavand posibilitatea sa scriu o memorie am incercat cu ce aveam la indemana din sasie chinezesti,si cel din tv la prima vedere fiind tot china dar pe el scrie made in egipt,dupa mai multe incercari am gasit una potrivita dar pe unele canale nu am culoare,cum as putea debloca memoria ? pt ca vreau sa o pun p cea originala,ma gandesc la MS dar nici din telec nu primeste comanda si cum se poate intra in service?tv-ul e model HRH-TF21componente:pro R2J10192GA 805B30bv LA 78040audio UTC 2003alim CQ0765 RT tot ce am gasit scris pe sasiu este IEP-GMT-01telecomanda RC-29 sau 5Z26 Quote Link to comment Share on other sites More sharing options...
dan-a2 Posted April 13, 2014 Share Posted April 13, 2014 Ai aici solutia postata de ,,mirceamtv '' http://www.elforum.info/viewtopic.php?f=17&t=68341 Quote Link to comment Share on other sites More sharing options...
Florinel TV Posted April 13, 2014 Share Posted April 13, 2014 incearca cu dumpul asta Quote Link to comment Share on other sites More sharing options...
tanase Posted April 13, 2014 Author Share Posted April 13, 2014 Ai aici solutia postata de ,,mirceamtv '' viewtopic.php?f=17&t=68341a mers perfect multumesc Quote Link to comment Share on other sites More sharing options...
Join the conversation
