kog1 Posted April 10, 2014 Share Posted April 10, 2014 Va rog sa mi spuna cineva ,care ar fi cauza de nu memoreaza posturile gasite ,nici reglajele ,sonor ,culoare si luminozitate (care sunt componentele care se ocupa de acest lucru ) Multumesc! Quote Link to comment Share on other sites More sharing options...
petcu_daniel Posted April 10, 2014 Share Posted April 10, 2014 Ce procesor are ? Quote Link to comment Share on other sites More sharing options...
kog1 Posted April 10, 2014 Author Share Posted April 10, 2014 Nu sunt sigur ,dar cred ca este M50431-101,nu se cunoaste bine scrisul .Multumesc ! Quote Link to comment Share on other sites More sharing options...
BUGHIU Posted April 10, 2014 Share Posted April 10, 2014 Asta ar fi vinovatul : procesor m50431-101sp Quote Link to comment Share on other sites More sharing options...
petcu_daniel Posted April 10, 2014 Share Posted April 10, 2014 Avem si M58655. Aceea este memoria. Posibil defecta dar in primul rand trebuie verificate tensiunile de lalimentare.Pinul 42-5V Quote Link to comment Share on other sites More sharing options...
iuliantv Posted April 10, 2014 Share Posted April 10, 2014 posibil lipsa -30v la pin2 M58655,am intalnit si eu defectul acum ceva ani buni,si ce ma chinuit,fara schema fara net,dar am avut noroc,-30 se facea undeva din unul din pinii trafului de linii,poate ave-ti noroc si dv,success Quote Link to comment Share on other sites More sharing options...
dan cod Posted April 11, 2014 Share Posted April 11, 2014 100% asta e problema lipseste tensiunea negativa la memorie.E o rezistenta si un cond care trebuiesc schimbate. Quote Link to comment Share on other sites More sharing options...
johnny79 Posted April 17, 2014 Share Posted April 17, 2014 Sau lipituri la mufe....placa cu procesorul si memoria este separata de restul ansamblului .....daca tensiunea de -30 V este prezenta,schimbati memoria....din cauza descarcarilor FIT se defecteaza. Quote Link to comment Share on other sites More sharing options...
validae Posted April 17, 2014 Share Posted April 17, 2014 Aceasi problema am avut-o cu un LG, am schimbat si memoria si degeaba.A fost nevoie sa schimb electroliticul de filtraj pe 8V si stabilizatorul de 5V si s-a rezolvat. Quote Link to comment Share on other sites More sharing options...
cristybadea Posted September 21, 2014 Share Posted September 21, 2014 Imi poate da cineva si mie schema la acest tv-sasiu va rog?multumesc Quote Link to comment Share on other sites More sharing options...
validae Posted September 21, 2014 Share Posted September 21, 2014 Vezi dacă seamănă cu ăsta : http://elektrotanya.com/contec_mv5198_mfp5398_chassis_p51-28-mb_60_a0539820-01_sch.pdf/download.html Quote Link to comment Share on other sites More sharing options...
palcu ion Posted September 21, 2014 Share Posted September 21, 2014 cauta aici Quote Link to comment Share on other sites More sharing options...
validae Posted September 21, 2014 Share Posted September 21, 2014 cauta aici Aici, unde exact ??? Ați uitat să puneți link-ul Quote Link to comment Share on other sites More sharing options...
dan cod Posted September 21, 2014 Share Posted September 21, 2014 Cred ca asta este shintoshi clasic cu sursa cu tranzistori.Am schema dar doar mâine pot atașa. Quote Link to comment Share on other sites More sharing options...
palcu ion Posted September 21, 2014 Share Posted September 21, 2014 http://www.postaonline.ro/z65hvk3m7o6z/p51-28_chassis.pdf.html Quote Link to comment Share on other sites More sharing options...
Join the conversation
