amatorul Posted April 8, 2014 Share Posted April 8, 2014 Am un tv hyundai HRH-TF2110 cu sasiu IEP-GR-AV2 care se vede alb-negru. Problema e ca se vede doar pe canale adica meniul este colorat si bluescreenul este normal.....am schimbat selectorul de canale si problema persista. Ce ar putea fi? Quote Link to comment Share on other sites More sharing options...
dan cod Posted April 8, 2014 Share Posted April 8, 2014 Nu are treaba cu tunerul.Ceva in zona jungla poate quartzul.Ce jungla are? Quote Link to comment Share on other sites More sharing options...
BUGHIU Posted April 9, 2014 Share Posted April 9, 2014 Daca nu ''vrea''color dupa ce ati schimbat quartul ,incercati un dump:viewtopic.php?f=17&t=153533 Quote Link to comment Share on other sites More sharing options...
amatorul Posted April 9, 2014 Author Share Posted April 9, 2014 am schimbat quartzul si degeaba,jungla e formata cu r2j10192ga-a00dd Quote Link to comment Share on other sites More sharing options...
dan cod Posted April 9, 2014 Share Posted April 9, 2014 Incearca cu dumpul asta. Quote Link to comment Share on other sites More sharing options...
amatorul Posted April 9, 2014 Author Share Posted April 9, 2014 momentan nu am cu ce programa memoria si nici nu prea stiu cum se face ca nu am facut niciodata Quote Link to comment Share on other sites More sharing options...
dan cod Posted April 9, 2014 Share Posted April 9, 2014 Citeste aiciviewtopic.php?f=266&t=119364 Quote Link to comment Share on other sites More sharing options...
amatorul Posted April 9, 2014 Author Share Posted April 9, 2014 multumesc,voi incerca Quote Link to comment Share on other sites More sharing options...
amatorul Posted April 10, 2014 Author Share Posted April 10, 2014 am rezolvat,am program memoria si acum vede color dar am facut o prostie cand am umblat prin meniu si am activat modul de blocare pentru copii si acum nu mai iese din stand-by. Quote Link to comment Share on other sites More sharing options...
elmar Posted April 10, 2014 Share Posted April 10, 2014 nu porneste din telecomanda?daca nu porneste ...reprogramati memoria ...si de data asta umblati mai cu atentie in "meniu"! Quote Link to comment Share on other sites More sharing options...
amatorul Posted April 13, 2014 Author Share Posted April 13, 2014 am reprogramat memoria si acum merge Quote Link to comment Share on other sites More sharing options...
amatorul Posted April 17, 2014 Author Share Posted April 17, 2014 Am revenit cu o problema la acest tv,pe unele canale imaginea depaseste ecranul pe verticala,nu am observat asta prima data caci l-am verificat pe un canal ce transmitea 16:9....sa nu fie dump-ul potrivit pt acest tub? Quote Link to comment Share on other sites More sharing options...
Join the conversation
