Jump to content
PALLADIUM T-2035GRZ
Va salut, rog frumos o schema, componente: CTV222S, TA8659AN, TA7680AP, 74HC241AP, TC4053BP, LA7910, BV si SURSA cu tz. ,pe placa scrie GO1-A3200, DEFECTUL imagine desincronizata H , OSD se afiseaza corect, dimensiunea V se regleaza corect, lipsa sunet , poate e un defect tipic !?
Link to comment
Share on other sites
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
 Share
  • Create New...
Important Information
