surubarila Posted April 8, 2014 Share Posted April 8, 2014 Sanatate permanenta!As vrea sa salvez de la reciclare acest TV.N-am reusit sa gasesc schema.Nu ii stiu istoricul dar e "cotrobait" in zona sursa si trafo linii,din fericire nu la componentele smd de pe spatele placii.Contine:P6NB80FP+TEA2262-sursa,SAA5297PS/262-contr.,TDA8843-jungle,TDA8350-b.v.,STV5112-video,OREGA40348A-03-trafo linii(posibil schimbat pe placa cineva a scris HR8624).O schema daca aveti m-ar ajuta.MULTAM! Quote Link to comment Share on other sites More sharing options...
tehtronics Posted April 8, 2014 Share Posted April 8, 2014 scrie pe eticheta: Art.Nr. xxx / xxx ? Quote Link to comment Share on other sites More sharing options...
santamihai Posted April 8, 2014 Share Posted April 8, 2014 http://elektrotanya.com/orion_professio ... nload.html Quote Link to comment Share on other sites More sharing options...
surubarila Posted April 8, 2014 Author Share Posted April 8, 2014 Pt Tehtronics-ART Nr 765/293X-x e inca o cifra posibil 1(nu se vede bine).Santamihai-o descarc acusi!Multam! Quote Link to comment Share on other sites More sharing options...
tehtronics Posted April 8, 2014 Share Posted April 8, 2014 atunci, confirm sasiu Orion Professional 4400 Quote Link to comment Share on other sites More sharing options...
surubarila Posted April 8, 2014 Author Share Posted April 8, 2014 Multumesc domnilor!Aceea e schema,daca-mi reuseste va anunt. Quote Link to comment Share on other sites More sharing options...
surubarila Posted April 18, 2014 Author Share Posted April 18, 2014 Sanatate permanenta si sarbatori cu bine!Am aflat cauza defectarii TV-a fost "traznit".Singura componenta din sursa(nu pleaca) pe care n-am cum s-o verific e TEA2262,restul sunt OK.Am "manarit" o sursa de TV ALFA 61T(rusesc) si am obtinut cele 4 tensiuni pe care le scotea sursa originala.Tv-ul porneste OK face st-by si on cu telecomanda LCD-ului MAXWELL(al meu) schimba programe,reglaje de baza-volum contrast etc. mai putin programare posturi.Este IRC81389 telecomanda care-i trebuie si daca nu care ar fi potrivita?MULTAM! Quote Link to comment Share on other sites More sharing options...
surubarila Posted June 20, 2014 Author Share Posted June 20, 2014 Revin cu TV-ul si cu rugamintea de a-mi da cateva sfaturi.Am cumparat TEA2262 si tz-ul din sursa.Inainte de a monta CI am mai verificat si gasit defecte:ZP2/ZP3+optocuplorul ICP2.N-am avut zenere smd si am pus(de proba) doua DZ6V2 iar oc. am luat din recuperate corespondenta pinilor fiind la fel.Se intampla asa:cu bec de 60W porneste sursa,tensiuni OK,B+ regleaza.Pe capacul TV scrie consum de 90W,daca pun bec de 100W B+ scade de la 150V la 110V inclusiv cu sasiul(Orion Professional 4400) montat in tv,apare imagine dar redusa H/V.Cu sursa improvizata despre care am zis mai sus TV-ul functioneaza.Sunt ghinionist si am prins TEA stift ori e trf. chopper?Multam!P.S. am masurat/schimbat toate componentele primar-secundar sursa. Quote Link to comment Share on other sites More sharing options...
palcu ion Posted June 20, 2014 Share Posted June 20, 2014 si de ce nu pui un bec de 75w sa-ti iasa din pareri? Quote Link to comment Share on other sites More sharing options...
surubarila Posted June 20, 2014 Author Share Posted June 20, 2014 Multam pt. idee!Cred ca am pe undeva un bec de 15W sa-l pun peste cel de 60.Maine o sa vad ce si cum.Oare 0,1A sa faca diferenta? Quote Link to comment Share on other sites More sharing options...
leoncris Posted June 21, 2014 Share Posted June 21, 2014 "Cred ca am pe undeva un bec de 15W sa-l pun peste cel de 60" - esti tare domnule. Quote Link to comment Share on other sites More sharing options...
palcu ion Posted June 21, 2014 Share Posted June 21, 2014 de ce nu? pina la urma 60+15=75,nu? Quote Link to comment Share on other sites More sharing options...
surubarila Posted June 21, 2014 Author Share Posted June 21, 2014 M-am prins domnilor ca "ajutorul" dat de d-l Palcu e cumva nepotrivit,nu indraznesc sa-i zic altfel d-aia am si raspuns in aceeasi maniera.L-am reparat si sunt convins ca nu va intereseaza ce a fost defect.Va multumesc! Quote Link to comment Share on other sites More sharing options...
Emil 1986 Posted June 21, 2014 Share Posted June 21, 2014 de ce nu? Quote Link to comment Share on other sites More sharing options...
Florinel TV Posted June 21, 2014 Share Posted June 21, 2014 (edited) M-am prins domnilor ca "ajutorul" dat de d-l Palcu e cumva nepotrivit,nu indraznesc sa-i zic altfel d-aia am si raspuns in aceeasi maniera.L-am reparat si sunt convins ca nu va intereseaza ce a fost defect.Va multumesc! un topic cind este deschis este pentru toti daca postam intrebari postam si rezolvarea lor nu conteaza ca sint multi meseriasi pe forum ca ei stiu defectu dar mai sint si incepatori care trebuie ajutati daca nu postam rezolvarea lor ei nu pot invata de asta ne ajutam uni pe alti si so luam asa sint multe defecte care si la un meserias dureaza pina dai de defect si daca un meserias munceste mai mult nu inseamna ca trebuie sa munceasca toti pt acelasi defect eu cred ca de asta este deschis forumul sa ne ajutam reciproc succes si multa bafta tuturor Edited June 21, 2014 by Harhas Florin Quote Link to comment Share on other sites More sharing options...
Join the conversation
