Jump to content
Sign in to follow this
profimex
Tvc Daewoo 21h4t2
Buna ziua am un televizor Daewoo 21h4t2 sasiu CP082 si as dori sa stiu cum se poate intra in meniul service fara telecomanda speciala de service sau daca nu unde pot gasi o astfel de telecomanda .
Share this post
Link to post
Share on other sites
DAEWOO CP-082To enter the "SERVICE MODE"Press NORMAL => AV => SLEEP => CLEAR => POWER buttons in regularsequency within 10 seconds using USER REMOCON after setting ST-BY.
Share this post
Link to post
Asta din telecomanda de service nu cred ca merge din telecomanda normala.
Share this post
Link to post
S-au varianta aceasta1) Select the channel number on the TV 912) Set the minimum SHARPNESS3) Quickly press the remote (RED) - (GREEN) - (MENU)CN-011: Press the button on the remote (MUTE) (DISPLAY) (MUTE). Control (VOL UP) (VOL DOUN) (PR +) (PR-). Every change made in the sub need to remember, pressing the (DISPLAY).
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
Important Information
