Jump to content
Sign in to follow this
binox
Conectare in comun pini intrare intre doua Atmega8
E vreo problema daca conectez inte ele intrarile de la 2 montaje separate dar identice cu Atmega8 pt a le putea declansa simultan cu aceleasi butoane?
Share this post
Link to post
Share on other sites
Pinii ca intrari se pot lega mai multi impreuna , evident ca trebuie sa aiba si masa conectata impreuna cele 2 montaje
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
Important Information
